Backhoe slow,sluggish and loss of power
   / Backhoe slow,sluggish and loss of power #1
Dan Lamb
MC Cloud Ca
Branson 2400h TLB/ cab
Hey guys ,
I was running backhoe today and noticed it was a lot slower and a noticeable loss of power , I usually run about 18-1900 rpm and it reacts good , was at 22-2300 today and not good power or responsiveness, I am about 20 hrs over on my hydraulic oil and filters change could this be the problem ? I hope , thanks Dan, yes tractor was warmed up and I did check hyd level
   / Backhoe slow,sluggish and loss of power #2
Filter certainly could be an issue. Does the backhoe run off a remote valve on the tractor or is it power beyond setup where you have to hook the lines off the tractor together when not using backhoe?
If it runs off of remote, could possibly be valve spool is not moving enough to allow full flow.
Another question would be is the loader operating normally? If not, then filter is a great place to start.
   / Backhoe slow,sluggish and loss of power #3
If you have diverted valves to run the BH make sure they are all the way in or out as required. Also try re-seating the hydraulic quick connectors.
   / Backhoe slow,sluggish and loss of power #4
Filters would be my first thing to replace. Be sure that you find all of them. On my New Holland backoe, I have 3 hydraulic filters. Two are easy to find under the tractor, the third is inside the tank and a real pain to replace. You have to drain the tank to get to it!!!
Thanks guys ,
I’m changing all filters 1 hydraulic filter and 1 hydrostatic tranny filter that’s where I’ll start first , yes my power beyond does control my backhoe it’s a frame mount not a 3 pt hookup , thanks for the options guys , Nor Cal Dan
   / Backhoe slow,sluggish and loss of power #6
If you haven't bought your filters yet, be sure to shop around. I went to my dealer for the first time and felt violated by what they charged me. NAPA was cheaper, so I bought from them after that, but then I tried Amazon, and they where significantly cheaper. Ebay will sometimes have some filters for less then Amazon, but shipping takes longer and you have to factor in shipping charges, which sometimes makes Amazon a better deal, and sometimes Ebay is still worthwhile.
Wix Filters is what I use on all my stuff. They make most of the factory filters, so the biggest difference is the color of the filter. The part number is the same for all of my stuff from the factory filters to the Wix filters.
Wow,
Changed all filters and new hydraulic fluid , it made a big difference feels like it has 5 more HP , THANKS TO ALL WHO RESPONDED
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2002 Freightliner FL70 Sweeper Truck (NOT RUNNING) (A50774)
2002 Freightliner...
UNUSED AGT QUICK ATTACH FLAIL MOWER (A51244)
UNUSED AGT QUICK...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
