Backhoe backhoe removal fel not working HELP
   / backhoe removal fel not working HELP #1
f3504x4
richmond, va
kioti ck20 hst tlb
hi, i have a ck20hst and removed the backhoe today for the first time. now with the hoses disconnected from the front the fel wont go up. is there a lever or something i'm missing? please help., chris
its a kioti. and the hoses connect up front. they run through the frame.
   / backhoe removal fel not working HELP #4
Did you turn the control valve? -- If you follow the quick coupler back to where it mounts to the "main" part of the tractor there is a valve there that needs turned 90 degrees.
If it is facing outward turn it towards the back of the tractor or vice versa.
Kurt
I did the same thing myself. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Then I read the manual.
   / backhoe removal fel not working HELP #5
See attachment. The role pin needs to be in this position.
   / backhoe removal fel not working HELP #6
Here is the thread that Dewave did on the subject.
gerard, thanks so much for responding so fast. i checked and the pin was in the wrong pos. i will check tom. to see if this was it. i'm sure it was. you and everyone else is what makes this site so great. i sure hope one day i will know enough to help someone in there time of need. thanks again, chris
   / backhoe removal fel not working HELP #8
Glad I could help. Keep us posted on how you make out.
   / backhoe removal fel not working HELP #9
<font color="blue">gerard, thanks so much for responding so fast. i checked and the pin was in the wrong pos. i will check tom. to see if this was it. i'm sure it was. you and everyone else is what makes this site so great. i sure hope one day i will know enough to help someone in there time of need. thanks again, chris </font>
this is EXACTLY why i love this forum.. i've been in the same situation multiple times over the last 12 months. i know now that if i'm unsure of anything, i ask first.. THEN i drill holes..
pf
   / backhoe removal fel not working HELP #10
Gerard, I've attached another view of the lever in case someone has trouble locating it. The tractor won't even run right if this lever is still in the power beyond position after disconnecting the BH. Another thing, if the tractor doesn't seem to operate right and the loader doesn't work but the lever is in the correct position, check your quick disconnects as the same reaction will happen if one comes loose.
John
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
