backhoe question.
/ backhoe question. #11
Hire or rent a small excavator. Far cheaper and less time consuming in the long run.
/ backhoe question. #12
Depends ...
I'm usually only home for a day or three per month, as a long distance truck driver ... Can't guarantee any particular day most of the time, it's more of a "range" ... So renting would be a challenge to say the least ...
Can't really reserve it for a particular day ...
Rental place is 45 minutes each way, times two ...
What's your very limited time worth?
On my Massey Ferguson SCUT I can take off my quick hitch, tuck my 3pt stuff away, back up to my BH on my uneven gravel barn "floor", hook it up, and be driving out of the barn in 12-13 minutes, same time used to put it away and come back to 3pt QH ... For a small less than hour project this is much quicker than renting, even if they have one available.
I got mine for convenience ... Sometimes I only swing by under a load for 2-24 hours, and have my bosses semi-truck ...
/ backhoe question. #13
Does not make any sense for me to hire or rent.
Often only need machine for an hour or two each time.
Rental place is 1 hour each way.
/ backhoe question. #14
I have an L2950 with a Woods 7500 and use a sub frame. I have done extensive ditching, and culvert installs on my property (5 just this year) and ditched through extremely rocky soil maybe 400 feet. Rocks the size of basketballs every foot or two all the way. I have dug out huge rocks and stumps and I cannot Imagin having mine be a 3pt connection. I am very certain it would have broken the rear casting in many instances in the past. Sub Frame only, is my opinion. Hope this helps. JeffinMaine
/ backhoe question. #15
I have been fine with my Woods 3PH BH for the last 20+ years. Connecting and disconnecting definitely requires patience and attention. There are plenty of opportunities for something really bad happening, if you get careless and/or frustrated.
If I had to connect and disconnect it regularly, I might look for a better solution, but for occasional use, the convenience of having the implement on hand is worth the setup hassle.
/ backhoe question. #16
Great to see you back, my friend.
Did you know 5030 passed away?
Still have the L48, I see.
/ backhoe question. #17
He has not been back since he posted that. And before 5030 died...
No big deal, it just why I HATE "Similar Links" where old zombie posts are brought back from the dead... :mad:
Makes you wonder if Fred is alive or not... he posted a bunch, then nothing.
/ backhoe question. #18
A few months ago, I wondered if my late Uncle Fred had ever been a member, as he was a very technological/mechanical man and had some tractors, and would have done very well on this forum. His grandfather was a (locally) famous mechanic when mechanic-ing was first becoming a "thing", around the turn of the (last) century. He was also known to be the first person in the county to get a driver's license.
My uncle dropped out of school at 16, but still managed (without any additional formal education) to become the chief safety engineer for a P&G facility.
I searched every way I could think, but never found any hint of him on here.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
14C SCRAPER (A58214)
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
