backhoe question
   / backhoe question #31
According to Kioti that BH the 2485 should not be on that machine. take it back.
   / backhoe question
what will happen??????????????? he said only 31-35 lbs heaver. Getting worried now
   / backhoe question #33
I use boom I can lift about an 1nch an then put outrigger down and it wil hold. Is this answering what ya want to know?????
OH. If I try to lift both tires,NO, it will not take them off ground. Just 1 about an inch
Yes, this is what we wanted to know. In your first post (IIRC) you said you thought the outriggers were too short / not long enough.
What this tells us is that is not the case. But you have a hydraulic issue somewhere. Because they simply arent getting enough power to raise the machine, but are pleanty long enough.
And I agree with murphy1244, take it back. If kioti dont spec it for the machine, regardless of what some dealer "thinks", there has to be a reason. Kioti just doesnt take the time to complete design and build a different BH if they already had a model that would work. Now I dont know if having the wrong backhoe is causing your hydraulic issue, or if you have something else going on. Either way, I would be taking the WHOLE set-up back to the dealer (who dont sound too bright BTW). Make HIM fix it right.
   / backhoe question #34
Obviously it's not going to do everything shown in this video, but you should be able to lift the rear with the stabilizers as shown, and lift the rear with the backhoe, as shown. The car driving under it is just a bonus;)
   / backhoe question #35
Now thats power!! Can your machine do that??
   / backhoe question #36
Got a new ck35 with a kb2485 hoe an frame. This is 1 size bigger than normal but dealer said would work fine as it weighs only 35 ils. more than 2475. My question is when putting down outriggers they do not lift rear tires off ground. Is this normal or are cylinder too short???
Tested this last night with my CK30/2475 hoe just to be sure...
Boom up and Front Bucket(FEL) up off the ground, I can lift my rear tires off the ground ~3 inches each with the outriggers.
Boom up and FEL down on the ground, outriggers would NOT lift back tires off ground.
Boom down will lift the rear tires off the ground with the FEL up(recommended) or down on the ground(not recommended).
Just some level setting info.
   / backhoe question #38
That sounds fairly normal to me. I don't think you are far off...if at all, if it can do that.
   / backhoe question #39
I wish! It's really cool though. I can lift all 4 tires off the ground with the fel/stabilizers, and stared lifting it like done in the video, but you start going up and I got a foot off the ground and thought it's probably not the best thing to do for my tractor and it would really suck if I got it all the way up and it tipped over... So I stopped.
   / backhoe question #40
Yea, quite dangerous. Espeically with and older and sloppier machine.
Mine can do that, I have done it to an extent to get out of tricky situations. Balancing on JUST the bucket isnt really stable. And one wrong twitch of the swing lever and over she'll probabaly go:confused3:
2010 Chevrolet Silverado 1500 (A55973)
2010 Chevrolet...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2024 CHEVROLET SILVERADO 2500 HD BED (A58018)
2024 CHEVROLET...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 Case 5550 Trident (A56435)
2020 Case 5550...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
