Backhoe question
   / Backhoe question #1
Laneman
I looked at a New Holland 1925 with loader and Backhoe attachment today, asking price $10,500, 1000 hours. I have some questions. I've never used a backhoe, but this one only moves with one lever at a time. If two levers are used it will ignore one of them. Is this by design or is there a problem? Next question. The 3-point arms would not raise with the lever. Are they somehow disabled when the hoe is attached, or is there a problem with the 3-point?
   / Backhoe question #3
Yes, as Egon says, those are features, not bugs. Sounds like a good deal,
if everything is in decent shape.
Your tractor has only one implement pump, so using more than one spool
valve at a time will require some feathering and practice. Many many
tractors power their hoes by bypassing the 3-pt in the hydraulic circuit.
Re-enabling the 3-pt when the hoe is detached is usually easy.
Did you get an owner's manual?
   / Backhoe question
Thanks for the replies. No manual is available. My last tractor was a JD950, 30 horse with bigger tires and wheelbase than this one. I was wondering if this New Holland 1925 will handle the same workload, it seems small in the frame and wheelbase. I'm on hilly terrain and like a wider/longer footprint. I was thinking of buying this to do some side jobs, which would help pay for it. Think I can tow this with a 1/2 ton F150/small V-8?
   / Backhoe question #5
If it's really smaller than the JD950 -- yah, your 1/2 ton PU should be able to tow it. I had a JD 970 TLB and hauled it on a 7,000 lb trailer without any issues.
AKfish
   / Backhoe question #6
That sounds really lame to me. I don't think the pump puts out enough gpm to use the hoe properly. Why wouldn't the three point work independently unless it is diverted. I never heard of a senario like that. This is the reason alot of compacts have pto hydraulic pumps attached due to the low volume internal system.
   / Backhoe question #7
Once upon a time compact tractors had implement pumps that put out
only 3-4 GPM. That low flow limited the speed of hydraulic cylinders over
2 inches in diameter. That was one reason you saw a lot of PTO pump
systems sold. That is no longer true. Now many CUTs put out 6-9 GPM,
which is plenty of flow. Even the 1925 probably puts out at least 5GPM,
way more than say a Ford 8N.
Bypassing the 3-pt cyl for backhoe power is quite common, and the 3PH
is not usable with the hoe attached anyway. What's lame about that?
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
