Backhoe Project Photo
/ Backhoe Project Photo #1
Glenn1
Louisville, Ky.
B7500 Kubota
First I want to thank everyone for the info on attaching photographs. Apparently the file size was to large.
I ordered the drawings from Cadplans.com and the kit from Metkit Corporation. The kit included all tubing, brackets, bushings, pins, manifold, hoses, cylinders and even the seat. The material was well packaged and appears to be cut on exact size. Happy so far. /forums/images/graemlins/cool.gif
/ Backhoe Project Photo #2
<font color="blue"> First I want to thank everyone for the info on attaching photographs. </font>
Lesson 2 of attaching photographs is to post one message with an attached photograph then simply reply to that message and attach subsequent photos and not start a new message for every photo. /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/shocked.gif
/ Backhoe Project Photo #3
Rear photo
/ Backhoe Project Photo #4
Right side
/ Backhoe Project Photo #5
Great project. I'll be interested in following it. I'm glad to hear that the kit quality is good as I've looked into them myself.
I have been welding for thirty years and have seen a lot of fabricated steel. I was very impressed with the quality and workmanship. I just hope I can say the same thing about my part when the unit is completed.
/ Backhoe Project Photo #7
Lookin' good so far, Glenn1! May I recommend a point about the pins and bearings? Do what you can to make them greasable. Center and cross drill with zerks or purchase something already made. I used the bronze/graphite 'permamnently lubed' bearings and they're binding pretty bad. In fact, the pin at the boom-to-frame joint apparently locked up and caused the pin to wear on the upper and lower holes in the steel instead. Trying to figure out how to easily repair this hiccup....
The plans call for grease fittings and grinding a path for grease around the center of each bushing.
I sounds like you built the same machine, are you satisfied with the power and operation?
Did you have any other problems?
The metal kit was $822.00. Go to www.metkit.com for all pricing. They are very helpful with questions and problems. Give them a call.
2014 Ford Escape SUV (A59231)
2014 Ford Escape...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2009 FORD F-150 (A60736)
2009 FORD F-150...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61307)
2021 Gehl RT215...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
