Backhoe backhoe problems?
/ backhoe problems? #21
The kit puts what would otherwise connect to the rear remote marked 'B' into the reservoir directly via and adapter that moves the overflow's 'Shepard's crook' to the other side near the remotes, and allows the 'b' return line to connect into the reservoir fill location on the right, as viewed from the back of the tractor.
Does that answer your question?
If not let me know and I will detail it further....
I do not quite understand your explanation and I have a CK, not a DK.
Are you saying that your return is connected to your hyd oil fill port?
I have used this location on Kubotas before....I thought Kioti might have
something more elegant....
(ISLAND: COYOTE is using only one of the 2 work ports on his AUX valve
for power, and avoiding the restriction of using the other work port for
low pressure return to the reservoir.)
/ backhoe problems? #22
Sorry about the CK~ DK confusion- :eek:
Doesn't everyone have a DK? :p (just kidding)...
The adapter kit allows the return line to quick connect directly into the fitting that comes with the kit, so the reservoir fill port is blocked by the adapter. The quick connect male end which screws into the reservoir needs to be removed from the reservoir to fill the fluid- if needed.
Hope that is a clearer explanation?!
/ backhoe problems? #24
If I suddenly had to replace my main tractor, I would get a DK-SE HST.
If you get a chance, pls post a photo of the new return line connections.
I'll be glad to post a pic or two as soon as I find a second to do anything other than trying to clear my woods for the excavator for Monday to start on my 30'w x 40' deep barn/apartment building...
Also in middle of 30x30' addition with a 12'x 15' L on the end....
Phew.... I wish it was done- but things take more time than expected especially with all the rain :)
/ backhoe problems? #25
dfkrug,
Here are the pics! Hope they help explain how things are attached with the kit. Seems the return line QC is male and the original output line attached to rear port 'A' is female. The kit bolts where the reservoir fill is usually and replaces it with the QC for the return line. To fill the reservoir one has to disconnect the return line, unscrew the fitting and then pour fluid into the 'neck' that is bolted to the side of the reservoir.
/ backhoe problems? #26
Im looking to get a ck30hst with the kioti bh ,i have been around on this and some other sites and a few people voiced their concerns about the backhoes not holding ,or leaking down.I dont mind if it leaks down when im not on the tractor,but i dont want to be going through the woods and have to bump up everything every five seconds.Im looking at the 75 bh from kioti.Is this an old issue or what.I will be using the bh an awful lot ,building a house,culvert driveway,alot of leech lines.I wont have time to mess with a not so great backhoe.Thanks im getting ready to buy and dont want remorse.
If you are going through the woods or anywhere else just put the pins in.
Less stress and MUCH safer.
2008 Chrysler Sebring Convertible (A62679)
2008 Chrysler...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
1997 Ford F800 Dump Truck (A62613)
1997 Ford F800...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
2008 Big John 42' Log Trailer OFFSITE (A62613)
2008 Big John 42'...
