Backhoe problem
/ Backhoe problem #91
Last update, after 30 minutes of work
So TYM corporate said this is normal operation.?.
Bet they rethink that after the dealer sent the pic of the rod...
"it immediately starts moving really fast, then at about 1/5 of the way it slowed down almost to the stop, moving really slow with some hesitations on the way almost to the end, and the last 1/8 of the way it moves faster to the end.
My dealer recorded a video and sent it to the branson/tym.
As i expected branson try to shake of any claims.
They say it us supposed to be like that"
/ Backhoe problem #92
"......That impact at full swing is half of what is chewing up your cylinder pivot pins. And it could have also loosened up the piston rod in the cylinder - or broke something inside there."
Ah yes... well, bit congratulations on your determination. And you can cancel the friendly dealer's pressure test. It will be interesting to see what the Branson tech has to say. Just looking at it, my first guess is a classic compression failure - being close to a 45 degree angle and in the middle of the rod. Compression failures often start with a microfracture which grows in exactly that manner. A tension failure would be more likely to be a classic cup/cone and have some measureable necking.
In the Branson tech's defense, that is NOT a common type of failure. The whole group of us here on TBN only listed a rod failure as a "maybe"....not an absolute. My own guess when I saw the video showning what looked like excessive end play was that the rod-to-piston fixation was coming loose inside the cylinder. I never thought of the failure you are seeing. It has to be rare; backhoes get slammed around a lot in normal use.
rScotty
/ Backhoe problem
It broke approximately at 11 o'clock swing to the left. Question is, why the release valve did not open? It should be excessive pressure to do such damage
/ Backhoe problem #94
Which cylinder is this? Are you saying it broke all of a sudden? That must have been a surprise what happened?
I'm not sure that the release valve is involved in this failure, because I'm not yet convinced that type of rod fracture can be caused by the tractor's hydraulic system pressure - with or without the release valve working.
But I could be wrong. If you send some measurements for the rod length, diameter, and same for the piston OD or cylinder ID, then someone can do some rough calculations to ballpark the hydraulic pressures required to break the rod that way.
rScotty
/ Backhoe problem
What other forces could brake this in the middle of swing with bucket of gravel on flat ground?
/ Backhoe problem #96
Was the rod that broke still fully attached to the piston? Is the other cylinder rod properly attached to the piston.
/ Backhoe problem #97
If you put the pieces back together and put a straight edge on it is it straight? Wonder if it got bent somehow which might explain the uneven movement and subsequent breakage.
/ Backhoe problem #98
That rod failure is a mechanical issue with the backhoe. Either the stops are poorly located or the geometry sucks.
The backhoe should mechanically stop swinging before the cylinder bottoms. If it doesn’t, you bend rods or pop pistons off the rod. It may be a design issue or a manufacturing issue, or both.
The cylinders should not be side loaded by the backhoe while swinging. If they are, you fail things.
Your dealer needs to be heavily involved. If this is inherent design issues, you may need to ask for a return of the backhoe.
/ Backhoe problem #99
The relief valve only protects against over-pressure from the tractor's hydraulic pump .... and depending on the design, sometimes from hydraulic shock loads. The relief valve could be working fine and there still be other purely mechanical forces large enough to break the rod.
They other forces are probably more important now that the rod has broken because they are mechanical functions of the geometry of the backhoe. That is dealer and designer stuff.
One set of forces would happen if the rubber swing stops are not positioned right. You can see those rubber cushions in several of the photos. Those might be poorly located and allow the swing motion to stop by smashing into something solid instead of the cushion. That could start a fracture in the rod. Once a fracture starts, it doesn't take much repeated stress to make it grow. Just repetitions and time.
Or if the cylinder rods were bottoming out internally before the swing stops. That could do it.
Also, something less obvious could be putting side force on the cylinder rod. For example, the open end of the rod has to rotate around a pin. Does it have enough rotation or does something stop the rotation and cause the rod pin end to bind before the end of the swing? I've made that mistake myself.
All good ideas.
Dude also asked "What other forces could break this in the middle of a swing with a bucket of gravel.....?"
Well, there are also hydraulic forces that happen due to sudden changes in motion - especially when you close the valve and the swing suddenly stops. Having a load of gravel in the bucket makes those forces larger. Think of water hammer in house plumbing. Hydraulic forces from abrupt changes in motion are smaller than the mechanical ones of slamming against a stop - but still large. If the cylinder rod already had a crack growing from some other cause, those forces could be enough to cause it to come apart in the middle of a swing.
Or maybe you were just unlucky and got a rod with a defect. It happens, but that might be the best news of all. My guess is that the dealer is still involved in any of thes things.
Luck,
rScotty
Snap-On Zeus Diagnostic Machine (A61307)
Snap-On Zeus...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
Engine (A59228)
Engine (A59228)
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
