Backhoe problem
/ Backhoe problem #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
My boom will not stay up. Tried switchin hoses around to see if it might be the control valve, but no change. Would this indicate that the cylinder has a problem? Thanks for any help.
/ Backhoe problem #2
If the piston in the cylinder is extending when it comes down, it could be the cylinder.
How long does it take to come down?
/ Backhoe problem
The cylinder is contracted when the boom is up. It extends when dropping down.
/ Backhoe problem #5
Here is how I was taught to check the cylinder:
If it's not too difficult to do, I would remove the cylinder. Push the piston in all the way, and fill it with oil. Then, cap the threads where the hoses go. They are generally NPT threads. So, you can use pipe plugs.
Put the fixed end in a vice, or secure it in some way, and put a long screw driver, or rod through the other end of the piston, and see if you can pull the piston out.
If it only moves a little bit, and resists pulling all the way out, the seal is okay.
If it's leaking that bad, it should pull all they way out pretty easily.
If that's the case, you could start by inspecting the piston for defects, and replace the seals in the cylinder.
/ Backhoe problem #6
If you can safely remove one end of the cyl, then lets say the piston end. Put pressure on it and run the rod all the way out. Remove the rod end hose then put pressure to the base end, if oil comes out the rod end port you have bad piston seals.
/ Backhoe problem
Thanks for the help, I'll check it out today.
/ Backhoe problem
had a bad seal on the piston. waiting for parts now.
/ Backhoe problem #9
Good luck with your repair.
Tennant 7400 Compact Industrial Floor Scrubber (A61572)
Tennant 7400...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2014 International DuraStar 4300 S/A Dump Truck (A61573)
2014 International...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
