BACKHOE PART ??
   / BACKHOE PART ?? #1
DIRTCUTTER
New Mexico
CK30 HST
kb2375 Backhoe What is the part that is attached to the dipper that tells you when the bucket is level to the ground. Its a rod that slides in a tube. I looked in my parts manual no luck.I need to replace it, bent all to heck.
   / BACKHOE PART ?? #2
Never seen a level indicator on the backhoe...They are on the front loaders.
   / BACKHOE PART ??
You are right sir. Have been working in the hot sun and wasnt thinking when I posted.
Do you know whats it called
   / BACKHOE PART ?? #4
Bucket level indicator.
   / BACKHOE PART ?? #5
If the rod is all that is bent or even the tube, you might be able to weld the bracket on to a steel rod and/or tube from the hardware or steel supply store and make a new one. Maybe even make it out of stainless. Just a thought if you or a friend has a welder.
   / BACKHOE PART ?? #6
Do you really need it as front top edge of the bucket really tell you the angle your hitting the dirt with, i never really use the bucket level rod thingy.:)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
City of Lakeland (A51691)
City of Lakeland...
2004 MACK CX VISION (INOPERABLE) (A52472)
2004 MACK CX...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2014 Make...
