Backhoe on the Toolcat
/ Backhoe on the Toolcat #1
Rolando
Platinum Member
Northcentral Florida
Bobcat Toolcat High Flow Turbo C-series
What do you all think about whether something like this would work on the Toolcat and how well?
Easy Dig Mini Backhoe
I remember there's been some question about using a hydraulic unit but wondered if this was low tech enough to work. I know that you're not going to be tearing out any tree roots, but maybe digging a trench would be a possibility.
/ Backhoe on the Toolcat #2
I have used a skid steer mounted backhoe and on CUT. The TC does have more front end weight than most skid steers and that would help a little. However, unless your ground is very loose or very sandy, I think that design will work poorly.
Radman, is there a skidsteer backhoe out there that you think would work okay?
/ Backhoe on the Toolcat #4
Rolando,
There might be a time when that is the tool for the job, but in general I think you'll spend a lot of time moving your TC to move a small amount of material at a time.
Joe
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
UNUSED RAYTREE RMLL60-60" HYD POWER RAKE (A65055)
UNUSED RAYTREE...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
Generator (A64553)
Generator (A64553)
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
