Backhoe Backhoe off of tractor hyd.
   / Backhoe off of tractor hyd. #1
dieselram
Meadville, PA
2007 John Deere 3120 TLBM
I have a '05 L2800 with a Wodds 7500 hoe, my question is I think it would run faster and have more power if run off the tractor hyd system as opposed to the pto pump it has. How do you do it on this machine? My dealer does not know how so he just sells them with pumps.
   / Backhoe off of tractor hyd. #2
There is a kit that Kubota sells for the BH hook up. There are two hoses, one comes off the power beyond port on the loader valve and the other comes off the hydraulic block under the r/h step and there is a bracket that is mounted to the axle housing on the upper r/h side where the two hoses will connect to themselves via QD connector when bh is not connected to these hoses. I can't find all the pictures but these should help.
http://www.tractorbynet.com/forums/...-l3400-aftermarket-remotes-top-n-dsc00222.jpg
http://www.tractorbynet.com/forums/...-l3400-aftermarket-remotes-top-n-dsc00221.jpg
   / Backhoe off of tractor hyd. #3
Usually just the opposite is true. PTO pumps typically have more flow than the pumps on CUT's...
Can you post the specs (PSI and GPM) for your tractors implement pump and the PTO pump?
   / Backhoe off of tractor hyd. #4
I might be wrong, but from what i've read in these forums, there is more 'flow' and better to use a PTO pump. I can teell you that my ford 1720 runs much faster and easier and less throttle with the PTO pump.Have you checked on the flow per minute rate?
a couple of posts maybe of interest
http://www.tractorbynet.com/forums/...-take-off-rpm.html?highlight=backhoe+pto+pump
http://www.tractorbynet.com/forums/...vs-power-take.html?highlight=backhoe+pto+pump
http://www.tractorbynet.com/forums/...ff-vs-tractor.html?highlight=backhoe+pto+pump
I am sure some others will weigh in with opinions. I think youll like the Woods backhoe 20 plus years on mine and still going.
Al
Rhino DB150 (A57148)
2007 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2007 Vantage...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2002 Kenworth T300 TMA Attenuator Truck (A55973)
2002 Kenworth T300...
LOT: (6) Office Chairs (A59076)
LOT: (6) Office...
Freightliner Tender Truck - Adams Tender (A56435)
Freightliner...
