Backhoe Backhoe & Loader for JD 850
/ Backhoe & Loader for JD 850 #1
heiss1228
I am looking for advice on a good backhoe and loader for a JD 850. We have an old 850 that's in great shape in the family and I am trying to find the most economical way to get this setup. I realize this will be a bit on the smaller side, but it should be large enough for most jobs I plan on doing.
Thanks in advance.
/ Backhoe & Loader for JD 850 #2
This is not going to be cheap. Look at $4000 for the loader and $4500 for the BH. I like the Taylor Way BH for your size tractor. Do a search and you will find lots of info on them. Koyker makes a good loader with a nice valve and a kit to fit your machine.
You may save a few bucks here and there but you will be buying something with non standard valves, hoses, ect.
Chris
/ Backhoe & Loader for JD 850 #3
FWIW, if you like to / can fabricate, you could build a loader and backhoe.
P.F. Engineering has plans for a small loader and small backhoe. I bought his loader plans and am going to build it. I haven't decided whether to build a backhoe or not. You can scale it up a bit for your tractor. I figure the loader will be about half or less the cost to buy one. But I got the time to play around with it.
/ Backhoe & Loader for JD 850 #4
Another poster was asking about adding a FEL to a JD 750 on the JD forum and so I'll mention the same thing I cautioned him about. If your 850 has power steering, then you are in good shape with adding a loader. If it doesn't have power steering, then consider this....
When you add the FEL (about 400-600 lbs of iron and cylinders) and then have a full bucket load of material adding about 700-800lbs (or possibly more), then you have added probably around 1200lbs minimum of deadweight to the front end. Without power steering, you may have a difficult time turning the steering wheel!
If you plan on doing a lot of back and forth loader work involving a lot of turning without the PS, you may tire quickly of using the FEL. JD may offer a PS kit for the 850, but you won't like the price!
/ Backhoe & Loader for JD 850 #5
Look for a JD #8 backhoe along with a factory loader. Sorry I don't remember the model number for that, but there are aftermarket loaders that will fit it. Earlier this year one of our local business had a contractor build them a new store at a different location. All they used to do the dirt work and dig the trench for the foundation was a 850 JD with #8 JD backhoe, JD loader, and a box blade . It was impressive to see everything that 850 was capable of doing.
/ Backhoe & Loader for JD 850 #6
Thanks in advance.
Welcome to TBN:D
Does your machine have the joystick to operate a loader? If not then you definitely want a aftermarket unit that includes it.
But like DiamondPilot wrote, this is not going to be cheap, and probably not cost-effective either.
What attachments does the tractor have now?
Thanks for all the advice. This is such an informative forum.
I am preparing to build in the same neighborhood as my father-in-law. I've been using his 850 to clear the land and now I am needing a few more attachments.
Currently we have an auger, bush hog, tiller and rear blade.
This machine does have the controls for a loader, but it has never had one attached.
As for fabricating my own equipment - I really like the idea, but until I get my barn built I don't have a good place to do the work. Though I am getting spooled up to build the barn as we speak. I'm figuring a 39x60 will provide a little space for random projects and hope to have it completed sometime in early spring.
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
2015 Deere 210G (A64126)
2015 Deere 210G...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
