Backhoe Backhoe leaking fluid
   / Backhoe leaking fluid #12
Just take off the line next to it and tighten the loose one. There will be minimal fluid loss.
Might want to check your other lines though. Shouldn't take you that long at all to do.. 10 minutes at the most? Probably spend more time looking for your tools :)
   / Backhoe leaking fluid #13
The answer to your question: You need a flare nut wrench - a crow's foot flare nut wrench. Crow's foot is just the head of the wrench which you then turn with a socket wrench - great for tight spots. Flare nut variety is made to fit the fittings on your hydraulic hoses.
PALADIN INDUSTRIAL SCREENER (A58214)
PALADIN INDUSTRIAL...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A58017)
2003 VOLVO VNL...
