Backhoe Backhoe KB2375 "BROKE"
/ Backhoe KB2375 "BROKE" #11
Re: Backhoe KB2375 \"BROKE\"
The KB2375 is the newer model.
The KB 1550 was the prior model in that size.
/ Backhoe KB2375 "BROKE" #12
It did say on the kb2375
It did not say anything about the Kb1550
I don't have the exact answere for your question because I am only going by the paper work I had
I am also a Rhino dealer and did not receive anything from them about any problems
/ Backhoe KB2375 "BROKE" #13
Howdy, I have read about the cylinder pin that broke on your backhoe, ...... would you haVE A PICTURE OF THE DAMAGE
THANKS
CCARSE
/ Backhoe KB2375 "BROKE" #14
I have a Wallenstein 9' backhoe,and broke the very same pin .My pin is a 1" dia. with grease fitting on end of pin.To facilitate the grease fitting,a hole is drilled down the center of the pin from the fitting inward to the halfway point.At the midpoint a 1/4' wide groove is machined in . Another hole is then drilled into this groove (perpendicular to the first hole) joining the first hole midpoint. My pin broke at this mid point. I had no idea the pin was even broken,until I in the process of repairing a hydraulic hose discovered the trouble.My local distributor replaced the pin without question.
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2004 John Deere 4720 (A60462)
2004 John Deere...
MGY Shop Heater (A60463)
MGY Shop Heater...
2016 Deere 60G (A60462)
2016 Deere 60G...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
LMC 3pt 54' 300 Gal Boom Sprayer (A60462)
LMC 3pt 54' 300...
