backhoe hydraulics
/ backhoe hydraulics #1
Bladehauler
Brookshire TEXAS
LS R4047
My Backhoe ( an LS 2100 on my r4047 ) I believe has flow restricters in the lines making cylinder movement Sssloowww . is there any way to remove the restricters so I can control the cylinder speed with the spools instead of shifting full spool and waiting ?
/ backhoe hydraulics #2
You should be able to remove any restrictors. It could be a washer type orifice or a fitting drilled out.
As far as the spools giving you the feather depends if the valve was matched to the tractor hyd flow.
Some spools feather real good and others don't.
2022 EZ-GO ELITE...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
