backhoe hydraulics
   / backhoe hydraulics #1
Bladehauler
Brookshire TEXAS
LS R4047
My Backhoe ( an LS 2100 on my r4047 ) I believe has flow restricters in the lines making cylinder movement Sssloowww . is there any way to remove the restricters so I can control the cylinder speed with the spools instead of shifting full spool and waiting ?
   / backhoe hydraulics #2
You should be able to remove any restrictors. It could be a washer type orifice or a fitting drilled out.
As far as the spools giving you the feather depends if the valve was matched to the tractor hyd flow.
Some spools feather real good and others don't.
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
2000 Witzco Challenger RG-50 48FT 50 Ton Tri-Axle RGN Lowboy Trailer (A52377)
2000 Witzco...
