Backhoe backhoe hydraulic power
/ backhoe hydraulic power #1
guyrj33
Eastern MA
Kubota B7800
Where are your backhoe hydraulics conncected?
On my B7800 my Woods backhoe is connected to the 3pt hitch hydraulics. I don't have as much speed moving the backhoe as I would like. Can't raise boom and curl in the arm at the same time.
Dealer has checked and said it's normal?
Any opinions?
/ backhoe hydraulic power #2
I have a Woods 9000 on a L3130 using a remote and everything works ok. Sounds like you may be on the low side of the hydraulic flow requirement.
For example if my tractor is idling I can't lift the boom and curl the bucket at the same time. The bucket doesn't move, or doesn't appear to move, until the boom is up. The fluid takes the path of least resistance.
/ backhoe hydraulic power #3
What RPM's are you running tractor when operating the BH? My <font color="orange"> Kubota </font> BH will only run one cylinder at a time below 2000 RPM's.
/ backhoe hydraulic power #4
</font><font color="blue" class="small">( Where are your backhoe hydraulics conncected?
Any opinions?
)</font>
If your trying to raise the boom.. curl the bucket & bring in the dipper arm then no it won't happen...not three things at once, maybe on larger units.
I have noticed on my BH75 it doesn't like doin three things at once.
/ backhoe hydraulic power #5
Mine are ran off a separate PTO pump. If you want to do severel things at once it depends on the Gpm of the pump. Some put out around 12 GPM at a given pressure and I've seen some that can put out about twice that at the same pressure.
I'm running at full recommended rpm for implements, don't remember the exact number.
I'm only trying to do 2 things at once one on each joy stick.
Say lift the boom and bring in the arm, one will complete then the other will move. If I very verly lightly feather the controls I can move both at once.
I think the dealer should have sold me a pto driven pump with this backhoe.
/ backhoe hydraulic power #7
Sounds like it's working like it's supposed too. My uneducated opinion is, when giving a control lever full throttle, the first one in the series will get the power. That's why the swing motion is so fast and difficult to control. I repeat, this is my opinion from using my bh, I don't know for a fact.
/ backhoe hydraulic power #8
You need more flow is all, I do multiple functions all the time. One function at a time would just be slow, frustrating and uproductive to me. If my tractor did not have enough flow to do at least two functions at the same time I'd get a PTO pump that would.
I will get a PTO pump if that will solve the problem. Just want to know ahead of time that adding a pump will change the way the backhoe works.
The kubota and Woods specs seem to incidate enough flow, yet both Woods and Kubota seem to favor using a PTO pump.
When I can find the time I'm going to go back to the dealer and drive another B7800 with backhoe.
/ backhoe hydraulic power #10
I have B7610 with a Woods BH6500 - run off of the tractor hyd system no separate pump.
At lower RPMs the BH hydraulics are sluggish, I must say that i am not good enough yet to do 3 movements at once but I can operate the boom/curl/dipper any 2 combinations of the 3 without a problem.
BUT I can't swing & operate any other motion simultaneously I thought this was a safety feature and I don't really have any need to operate the swing & another motion simultaneously so I was never really concerned.
/ backhoe hydraulic power #11
Don't forget you can't just add a PTO pump. You will need a Reservoir to hold the fluid, And it will need to hold enough for the system to work.
/ backhoe hydraulic power #12
The standard PTO pump supplied by <font color="orange"> Kubota </font> and Woods has a Output of 6 GPM.
Your tractors hydraulics has a output of 6.4 GPM. Unless you get a larger pump than standard you will not see a increase in speed. To install a PTO pump you will also need a reservoir for pump to suck oil from.
One item that I have not seen mentioned here, is 3PH fully lowered or bypassed on your tractor?
/ backhoe hydraulic power #13
How are the backhoe outlets plumbed? It should be plumbed so that the backhoe inlet comes off the loader's power beyond and the backhoe outlet goes back into the circuit.
Do you have to jumper the backhoe connectors on the tractor together when the backhoe is not connected? If plumbed as above then you must have to jumper.
Is the 3pt lowered (as it should be) or raised?
You only have so much flow. The bh valve design will go a long way in determining which function has flow priority.
/ backhoe hydraulic power #14
I gonna have to get my memory checked /forums/images/graemlins/frown.gif
I was wrong about not doing three things at once, I can curl the bucket, bring in the boom and dipper arm in all at the same time just not real quick.
The Madref is right about the plumbing, it should go through your loader valve.
/ backhoe hydraulic power #15
I have a B7800 and Woods 7500 BH with PTO pump. My dealer advised getting the PTO pump rather than connecting to the tractor hydraulics and I think he was right.
I have no problem controling 3 functions simultaneously and have not found that I have to run the engine at high RPM in order to get reasonable responsiveness. If I ever get expert enough with the BH to think it is too slow, I guess I can run at higher RPM, which will increase the PTO pump output.
/ backhoe hydraulic power #16
</font><font color="blue" class="small">( Is the 3pt lowered (as it should be) or raised? )</font>
Hmmm...good point, I must have blew right past the 3pt hookup. Mine is connected to a remote. Does the 3pt restrict flow?
/ backhoe hydraulic power #17
My BH is PTO pump powered. I've often operated it at idle engine speed when working close to the house or near something that can easily be damaged. Usually has enough power to get the job done but it's just slow going.
Having the BH w/PTO pump setup has been good thing for me. /forums/images/graemlins/laugh.gif
(B2710 & BL4690B)
I was told the backhoe is plumbed off the 3pt hitch, and that I have to connect the hoses on the tractor together if I remove the backhoe.
I'm aware that a PTO pump would reqire a tank etc.
/ backhoe hydraulic power #19
</font><font color="blue" class="small">( I was told the backhoe is plumbed off the 3pt hitch, and that I have to connect the hoses on the tractor together if I remove the backhoe. )</font>
Not technically true about <font color="blue"> plumbed off the 3pt hitch </font> . For your configuration, the hydraulic circuit was broken after the loader but before the 3pt. The inlet of your backhoe is actually plumbed off the loader's power beyond outlet and your backhoe's outlet is plumbed back into the circuit before the 3pt.
That is why you have to jumper the connections when you remove the backhoe, otherwise the 3pt will never work and the pump will stall out and probably fail because you no longer have a closed loop for the fluid to travel from the pump back to the reservoir tank.
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2024 SCHWING SP 750-15 T-4 (A67737)
2024 SCHWING SP...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
UNUSED JCT HYD AUGER DRIVE AND BITS (A65055)
UNUSED JCT HYD...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
