Backhoe Hydraulic Hook ups
   / Backhoe Hydraulic Hook ups #1
Kryton619
Ontario, Canada
Mahindra 3016 Yanmar VIO 55 Excavator
I have a 3016 with a backhoe. My question is can I connect my log splitter hoses to the fittings that I normally connect the backhoe to?
   / Backhoe Hydraulic Hook ups #2
You should be able to as long as your splitter has its own valve and it is an open center type. Meaning that the lines from the splitter should be open when the valve is in its center position.
   / Backhoe Hydraulic Hook ups #3
I think most of them are, pretty sure mine is. Three position lever, down, open center and up.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
