Backhoe Backhoe hydraulic hook up
   / Backhoe hydraulic hook up #1
jimmyj
Elite Member
Ontario Canada
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
Can I hook the lines up backwards on a 2475 backhoe. The manual says "red here and white here" for the 2 lines but there are no red or white ties on mine.
Would it do harm for them to be reversed?
   / Backhoe hydraulic hook up #2
The oil would flow in the opposite direction and the controls would move things opposite than normal. I did this last time I hooked up my BH... I just changed my valve from the 'A' position to the 'B' position and all is operating normally.
OK that makes sense. Thanks.
   / Backhoe hydraulic hook up #5
I can not as the male and female fitting set up would not permit.
Joel
That is very interesting Joel. Why would they change it so the settings are the same now? That seems odd.
   / Backhoe hydraulic hook up #7
agreed.
On my machine, the connections at the tractor for the backhoe are one male and one female. No way to cross them up.
I really like the way my backhoe mounts to my machine, the four point set up works well.
Only thing I wish for is a little more length on the hose from the hoe making so I don't have to be super close to hook up prior to mounting.
Joel
   / Backhoe hydraulic hook up #8
agreed.
It does seem logical to do what you have done but most equipment intended to be run by rear remotes seems to be based on having two male connectors. I find that I can just put a ziptie on one of the males on the implement and one of the females on the tractor and that helps me remember to put things in the right hole. My wife gets very upset when I try to put my connectors in the wrong hole.:D
Ha ha
I put zip ties on them all now so I know what to do next time. Would not want to be in trouble with the wife like Island!!!:eek::eek::eek:
2016 Wilson Hopper Bottom Trailer (A50514)
2016 Wilson Hopper...
2012 Hino 262 Rollback Tow Truck (A50323)
2012 Hino 262...
2023 Icon I40L Electric Cart (A50324)
2023 Icon I40L...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
John Deere 6210E 120HP 4WD Agricultural Tractor (A50322)
John Deere 6210E...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
