Backhoe Backhoe Hyd. leak
/ Backhoe Hyd. leak #1
wanasrx
NY
Kioti 3054
The two pistons that turn the hoe side to side leak when they are near they're maximum limit. They leak where the piston comes out of the cylinder. Right from the holes that are in the metal seal area. Is this nomal?
/ Backhoe Hyd. leak #2
When you say leak do you mean running or just wet?
It is not normal to have a leak there
How many hours does the machine have on it?
Some cylinders have a set screw holding the ends on some have a big threaded nut.and some have a big C clip make sure they are tight.
Also check for damage on the chrome part that may result in tearing the seals.
/ Backhoe Hyd. leak
The leak isn't coming from around the seal but right out of the hole. It gushes right out. I'll have to look at it closer tonight.
Thank you for your reply.
/ Backhoe Hyd. leak #4
One of my cylinders seems to be leaking around the same spot. I called it into my dealer 2 days before the warrantee went out on the backhoe and I was told if I didn’t get it too them right then I wouldn't get it covered 100hrs (now 130hrs). So now I am out of luck and just letting it happen until winter when I can take it off and have the cylinder rebuilt. I asked about the extended warrantee also but never got a final word on it. So I will just deal with it myself until winter. I don't know that mine is leaking a ton from this location but it leaves a spot on the trailer every time and it gets super dirty on the cylinder every time I work due to it leaking.
/ Backhoe Hyd. leak
Here's a pic of the cyl. end. It leaks out the hole. Seems to me that it's some kind of a relief port maybe?
/ Backhoe Hyd. leak #7
The backhoe warranty is one year, not 100 hours. The backhoe does not have an hour meter. If you're talking about the swing boom cylinders, they are on the backhoe, not the tractor and should be covered for one year from purchase.
John
/ Backhoe Hyd. leak #8
You have a seal that is out. As said above, take it to any hydraulic shop and they will be able to fix you up.
/ Backhoe Hyd. leak #9
I called it into my dealer 2 days before the warrantee went out..... only 100 hours on the tractor at the time but still 2 days prior to the warrantee running out.
/ Backhoe Hyd. leak
Is there a rebuild kit that I could install myself? Also, if I took it somewhere to be fixed, is it that generic that they would have the parts in stock?
Thanks for the replies
Rich
/ Backhoe Hyd. leak #11
If your dealer would go to bat for you then Kioti should cover it. I am almost 99% sure they will cover the parts needed to fix it. I had a loader one time that was a tad out of warranty and a hose blew, I called Kioti and they covered the parts for the guy no problem. I don't understand why your dealer could not take care of this for you, it should not be a problem to have it covered.
/ Backhoe Hyd. leak #12
</font><font color="blue" class="small">( I don't understand why your dealer could not take care of this for you, it should not be a problem to have it covered.
)</font>
I'm with you on that Jon, especially since he called the dealer and made him aware of the problem before the warranty ended.
I'd give the dealer a call and suggest he try that given the circumstances.
John
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A67714)
2007 PETERBILT 335...
2020 CATERPILLAR 289D3 SKID STEER (A65056)
2020 CATERPILLAR...
213130 (A64276)
213130 (A64276)
Case SV300 High Flow Compact Wheel Loader Skid Steer (A66734)
Case SV300 High...
PORTA POTTY (A67714)
2013 Toyota Tundra Crew Cab Pickup Truck (A66736)
2013 Toyota Tundra...
