Backhoe Backhoe for Massey 135
   / Backhoe for Massey 135 #1
mjb34500
Creedmoor, NC
1968 Massey 135
I was wondering how safe/feasible it would be to put a universal PTO backhoe implement on the back of my 135? Would it be prudent to fabricate a frame for it?
   / Backhoe for Massey 135 #2
Hello mjb34500,
I have got a Massey Fergusson 35 and I converted a Backhoe used on a skid steer to 3 pt mounting. After lifting it with the 3 pt it is secured by adjustable rigid beams to the tractor at the fixing points just below the top link attachment. The first picture shows the backhoe with my simple thumb. The second is a close-up on the mounting. You can see the yellow beams going to the same pins as the 3 pt and also the yellow top link, which is forked at the tractor end going to the same fixing points as the beams. Unfortunately I have no picture available showing the tractor ends and as I am not getting back to Sweden for another month so I cannot get a better picture now.
This arrangement has worked for me without problems although the output from the hydraulic pump in the tractor does not allow speed digging. It is working fast enough for my needs.
   / Backhoe for Massey 135 #3
If your looking for a good used hoe to fit on your 135 send me a note....Do you have a Loader? Unit I have is a B15A Kelly Hoe. Has self contained hydraulics that work off PTO...$ 2,995 Located in SC 864-940-9341
WOODS 1033674 SUBFRAME KIT (A57192)
WOODS 1033674...
LaneShark LS3 (A56469)
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A57024)
2006 Heil Tanker...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
QUICK ATTACH COUPLER (A57192)
QUICK ATTACH...
