Backhoe Backhoe for BX2200? Is there?
   / Backhoe for BX2200? Is there? #31
</font><font color="blue" class="small">( The only bad thing about the Kwik-Way BH is that it is not a quick attach/dettach subframe system. To have the BH on you must remove the 3-point arms and MMM. So switching between the BH and mowing or using the 3-point would take I'd say about an hour or so. )</font>
This is true. The 3-pt on the BX-2200 was not designed to be removed "easily" like it is on the BX-22. Requires tools and elbow grease on the 2200!
   / Backhoe for BX2200? Is there? #32
I guess I would consider the extra time as a bonus....get to spend more time in/on/around my machine!
   / Backhoe for BX2200? Is there? #33
By the way, Kwik-Way has been around a long time and the equipment they make is very well made. If you do get it you will not be disappointed with it's craftsmanship.
   / Backhoe for BX2200? Is there? #34
</font><font color="blue" class="small">( I guess I would consider the extra time as a bonus....get to spend more time in/on/around my machine! )</font>
That would be true, but judging from the parts diagram for that portion of the BX...it's not a fun job to remove and re-install the 3-pt on the 2200. Someone in another thread speculated about adapting the BX-22 3-pt mounting hardware, but it was still unclear if that is "easy" or "hard"...there are some differences in the machines.
   / Backhoe for BX2200? Is there? #35
Check that other thread, I indicated what would need to be done to accomplish this conversion.
   / Backhoe for BX2200? Is there? #36
</font><font color="blue" class="small">( Check that other thread, I indicated what would need to be done to accomplish this conversion. )</font>
Thread title? Premature Senior Moment here...<G>
SKID STEER ATTACHMENT RAKE (A58214)
SKID STEER...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
