Backhoe float
   / Backhoe float #1
jel1988
Elliot Lake, ON
2012 Mahindra Max 22, John Deere D120
What does the float on a backhoe do? How is it used?
   / Backhoe float #2
My backhoe has no float on the hoe. The Front loader has a float setting. is that what you mean?
More details on the question would be helpful.
   / Backhoe float #3
If it like the Woods backhoes, it is a safety feature on the boom circuit to keep from getting crushed if something breaks.
   / Backhoe float #4
The BH float is used to do the final smoothing at the bottom of the trench.
Set the bottom of the bucket flat, then put it in float, it won't dig in, just scrape.
   / Backhoe float #5
Mine doesn't have float but if I do crowd and lift at the same time I get the same effect and I can trim the curl as it comes in. Mine's an old 4-lever so I just pull the 2 left levers in together.
Tafe 45DI (A50123)
Tafe 45DI (A50123)
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
Pallet of Lights (A53117)
Pallet of Lights...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2013 Kubota F2680 (A50123)
2013 Kubota F2680...
