Backhoe Carryall?
/ Backhoe Carryall? #1
Root Cause
Platinum Member
North Carolina mountains
Mahindra 2638
Like everyone else, I have wished for a carryall that is handy, low to the ground, and out of the way.
I have a backhoe that I need to keep mounted as ballast and started thinking about the square space on either side of the backhoe or just under it that is available. It isn't intuitive to use this space without good connecting points but there is a lot of space available.
It is at my other property so I can't look at the stabilizers today but it would be a great spot for access and it stays within the tire track footprint. I am wondering if it could be attached at two points, one stabilizer and somewhere on the backhoe.
Anyone with an opinion or observation is appreciated.
/ Backhoe Carryall? #2
I bolted some $5 auction find toolboxes to a pallet with some scrap wood & a few scrap pipes to holster hand tools. Move it around with the pallet forks. In your situation I'd look at some kind of frame or pallet you could scoop up & cary with the bucket.
Being able to drop my "fencing pallet" somewhere in a few seconds then use the tractor normally for whatever other task is so handy. Much more convenient than having something harder to mount or detach.
/ Backhoe Carryall?
Yep, I have the grapple on now and I need ballast in the back. I just found some scrap tubing so I will cobble up something in a week or two. thanks for pic. That helps.
John Deere MX6 Bush Hog (A64047)
John Deere MX6...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2012 Ford F250 Service Truck 4X4 (A64047)
2012 Ford F250...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
