backhoe bushings and hardened pin from ?
   / backhoe bushings and hardened pin from ? #1
john_bud
Super Member
Hi,
Where is a good (cheap) place to buy new pins and bushing for use in a backhoe?
Thanks,
john_bud
   / backhoe bushings and hardened pin from ? #2
JB, I called ford about the bushings in my ford 555B and they had them 121.00 + tx. I wint to General transmission, a local bearing/belt/shaft supplier and they made them for me in a couple hrs, 68.00 tx included. You might want to check with a machine shop in your area
   / backhoe bushings and hardened pin from ? #3
Try to find a hydraulic scrap yard it your area...........Cylinder rods make great hardened pins.
   / backhoe bushings and hardened pin from ? #4
On cylinder rods used for pins, remember cylinder rods are generally 10/45 steel, not hardened but the chrome plating is what gives cylinder rods their longevity. The steel *can* be hardened, if you've got a big enough torch. I built a backhoe attachment years ago and made my own hardened pins and bushings. I picked up an old kiln, about 3ft in diameter that someone had thrown out and made up the pins and bushings on a lathe. Then case hardened them using a product that MSC company sells, I believe it is called Kasenit (?) I can't be sure of the spelling, it's been 20 yrs.. It worked great. I know the dealer prices are an absolute rip off.
202481 (A54757)
202481 (A54757)
202483 (A54757)
202483 (A54757)
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
2019 Berky Weedo Amphi King 6450 (A56857)
2019 Berky Weedo...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
2012 International 4300 Reefer Truck (A56435)
2012 International...
