Backhoe buckets!
   / Backhoe buckets! #1
countrybumpkin
Elite Member
Kioti, kubota
Any one have or know were to get plans to build your own buckets for backhoes. i bought a case hoe for my Kubota and am needing a small bucket to go along with the 18 inch that is on it.
   / Backhoe buckets! #2
What about making a copy of what you have just narrower? Get some cardboard and make a template.
   / Backhoe buckets!
Guess that would work, Sometimes just don't see the obvious. What size bucket are people using for a small one. I was thinking around a 6" for running eletric lines or drain pipes stuff like that.
   / Backhoe buckets! #4
I don't think you can get down in the trench with anything less than a 12" bucket. Plus I would think that a 6" bucket might be a bear to keep clean (more apt to plug with moist dirt). We use a 12" bucket for our digging needs and it seems to work well.
   / Backhoe buckets! #5
I have a 24" and 12" buckets. A 12" trench is workable but its fairly tight. A smaller bucket would be ok for shrubs etc.. where your not working in the hole/trench. You may not want to go smaller than 8" or 10" because the dirt has a tendancy to stick in a narrow bucket. Others could probably comment better on that aspect.
   / Backhoe buckets! #6
I've got a 9" bucket that is great for running drain lines and electrical conduit.
Greg
   / Backhoe buckets! #7
</font><font color="blue" class="small">( dirt has a tendancy to stick )</font>
I've seen some weld short length of chain in trench bucket for that problem.
   / Backhoe buckets! #8
</font><font color="blue" class="small">( </font><font color="blueclass=small">( dirt has a tendancy to stick )</font>
I've seen some weld short length of chain in trench bucket for that problem. )</font>
Could you clarify what length chain and where is it welded
   / Backhoe buckets! #9
I made several buckets for my BH. Some plate steel, cutting bar, 3/4" stock for the pivot point brackets, a sledgehammer and an old stump. (These last two are v-e-r-y helpful for putting that gentle little curve in the bottom of the pan.) I used what I had and could scrounge up.
The smallest was a 12" which I found great for laying pipes and cables. It was reinforced and sharpened on all edges for cutting through roots. I got the teeth from a local Bobcat dealer and pinned them onto my home-made tooth mounts.
I also made a 16" for normal dirt digging and a 24" for culvert installations. The wider, the shallower to prevent strain on the little hoe.
As I recall, the dealer wanted several hundred $$$ each but I had less than fifty bucks in them all. /forums/images/graemlins/grin.gif
Go for it!
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
HYSTER 50 FORKLIFT (A52472)
HYSTER 50 FORKLIFT...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
