Buying Advice Backhoe attachment
/ Backhoe attachment #1
Imapipefitter
Can anyone give me some suggestions for different backhoe attachments that will fit a Kabota L3800? Also what kinda prices I can be looking at.
/ Backhoe attachment #2
Woods and Bradco are two that come to mind.
There are others out there.
hugs, Brandi
/ Backhoe attachment #3
A Kubota dealer can quote you for a Kubota BH and there are other companies making good products, as noted. Be aware there are essentially 2 types of backhoe attachment, those that use the 3 point links and those that have a dedicated subframe mounted on the tractor for attaching the backhoe. The subframe type is more heavy-duty and puts less stress on the tractor, generally a better way to go, even if it's somewhat more costly. You need to have the front end loader already installed to add a backhoe.
Speaking of which, expect to put $7-8k into a new backhoe.
/ Backhoe attachment #4
Definitely get a subframe. I have sheared bolts on my subframe. Imagine what would happen if my backhoe was hanging off the 3PH?
hugs, Brandi
I think I'm getting a good deal then. The dealer I'm working with quoted me $6880.00 for a BH77 with the package deal I'm getting a L3800 loader, finish mower, rock rake also. All for around $26600.00. That's with the backhoe all installed ready to work.
/ Backhoe attachment #6
That makes sense given you're buying the BH with the tractor - you do normally get a bit of a discount that way. From your first post, it sounded like you were looking to add a BH to an already owned L3800, in which case, you'd be paying more for it. Enjoy your new rig.
2005 Rolls Rite 26ft. 24 Ton T/A Tag Tailer (A61573)
2005 Rolls Rite...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
2017 Nissan Pathfinder SUV (A61574)
2017 Nissan...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
