Backhoe Attachment for 4600?
/ Backhoe Attachment for 4600? #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
Hello -
Does anyone have any experience with the JD Backhoe attachment on a 4600 series tractor? I'm thinking about buying one and I'm wondering what would be required to attach it (additional hydraulics, etc.). I'm also wondering about cost, too.
I guess I just can't have enough attachments.. that and I'm having too much fun with it now to NOT have the extras.
Thanks for your help!
-Bob
/ Backhoe Attachment for 4600? #2
The 4600 would go with the 48 hoe. I have a 48 on my 4300. It is one digging machine. /forums/images/graemlins/grin.gif You will have to get the "power beyond" kit to hook up the hydraulics for the hoe. The hoe attaches to the tractor via a couple of mounting plates that stay on the tractor. With the rockshaft assist setup the connection is nearly effortless and can be accomplished in less than 5 minutes without even getting off the tractor, assuming you already have the 3ph parts removed. The price should be around $6k.
/ Backhoe Attachment for 4600? #3
I've got one and use it all the time. I've used it for about everything you can thing of from putting in septic system, building, stumps, etc. It's a great attachment for sure. Like was said all you need is the power beyond kit and you are ready to hook up.
Thanks for the feedback. It sounds like once I have it attached, it probably wouldn't be removed too often as I would have to monkey with re-attaching the 3-pt arms everytime. Is this an issue?
6K seems like alot. I wonder if I can rent one for a short time to do any work or not. I would still need the kit from what you're saying so I guess it's not an option and I'd just have to plunk down and get it.
Any thoughts? I currently have a Frontier Box Blade and 72" Buehler Finishing mower that I use on the 3-pt - having to swap attachments sounds like it could be a problem.
-Bob
/ Backhoe Attachment for 4600? #5
You can buy the power beyond kit seperately from the hoe if you want. According to the JD configurator it is part # LVB25220 $195.00. I don't think putting the 3ph parts back on is a big deal. It only takes a couple of minutes. The dealer might let you try out the hoe if he thinks there is a good chance you'll buy it. Can't hurt to ask. /forums/images/graemlins/wink.gif
/ Backhoe Attachment for 4600? #6
I guess it all depends on what you consider an issue. It probably takes 15 -20 minutes to put the backhoe on and off if you consider the three point arms, the hoses, getting the backhoe just right to get it off, etc. I put mine off and on once or twice a month. To me it's not a big deal but it's not as easy as just hooking and unhooking a 3 pt. implement for sure.
I doubt you could rent one. I think list on that backhoe attachment is in the $7k range. The power beyond you do need a little know how to put on too. I'm not sure what they would charge you to do it.
Thanks for the feedback. I'm going to have to look into it a bit more and see what the dealers locally are saying.
-Bob
/ Backhoe Attachment for 4600? #8
Hello, I am a new member and found this thread about the JD 48 backhoe. I have a JD 4600 4wd and found a JD 48 backhoe that came with a subframe from a JD 5205. I need to find the Rockshaft assist setup for the 4600. Or adapt the subframe which came on the backhoe. ANY ADVICE MUCH APPRECIATED. Happy Thanksgiving!
/ Backhoe Attachment for 4600? #9
Start a thread in the owning/operating section, you'll get a lot more visibility.
Vegetable Sprayer (A60462)
Vegetable Sprayer...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
Electric Motorcycle (A64194)
Electric...
CAT CB34 (A60462)
CAT CB34 (A60462)
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
2011 Dodge 2500 Service Truck (A63116)
2011 Dodge 2500...
