Backhoe backhoe attached to fel
   / backhoe attached to fel #1
ewan
ns
kioti
Hi Everyone had an idea and was wondering if anyone has done anything like this, I have a kioti ck27 and have just acquired a small backhoe attachment (MF CB05) and was thinking of mounting it on a quick attach plate for the loader rather than trying to design/build a subframe plus it would make it easier to take off. The hoe is a little small for the tractor but the price was dirt cheap so couldn't pass it up and it should do what I want around the yard. Any pro's, con's thoughts, ideas would be appreciated. thanks
   / backhoe attached to fel #2
I think you'll damage if not destroy your loader with the forces produced by the backhoe attachment
   / backhoe attached to fel #4
I know Bobcat make a model 607 and 709 for their skidsteers but the skidsteer loaders are much more beefy than on a CUT. I think the trailer would be the ultimate. That way it could be towed anywhere.
   / backhoe attached to fel #5
It’s a terrible idea. Even most skid steer backhoes which have much beefier loaders have brackets welded onto the machine body.
   / backhoe attached to fel #6
Yes but the backhoe's on the Bobcat machines are also chained to the arms because they had an issue with the quick attach failing and they are also secured to frame mounts on the properly specified skid-steer or I guess CTL. My friend had one and said it was a pain in the butt as you'd have to jump off that seat to advance your trench or reposition the machine.
Hi Everyone Thanks for all the input, looks like a subframe in the future
2008 Ford F-550 4x4 Rugby Mason Dump Truck (A55852)
2008 Ford F-550...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
Electric Mobility Scooter (A51694)
Electric Mobility...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
black Max power washer (A53421)
black Max power...
