Back up switch for JD LT150
   / Back up switch for JD LT150 #22
I buy a new Garden Tractor every two or three years (I like new mowers) First thing I do is bypass all the stupid switches . The backup switch and the seat is the first to go .
My Mower tractor work like I like it to not like some fool thinks it should .
   / Back up switch for JD LT150 #23
:duh:
That's a debate for another place.
:wrench:
Double duh: spanner, while you maybe knowledgeable about the JD machines, you apparently don't know much about how to treat people and respond to them.
I, like others I'm sure, find your attitude a little overbearing. Please keep offering advice to the help seekers here, but please keep you comments to yourself.
Richard
   / Back up switch for JD LT150 #24
Well I mowed my lawn today, and when I needed to go into reverse I depressed the button , first then the pedal and it still shuts down. Anymore ideas?
   / Back up switch for JD LT150 #25
I bought a used L118 and am restoring it. It has mowed in reverse with no action on my part since I got it. While replacing the dashboard I discovered the two wires that connect to the underside of that switch are disconnected from the switch and just connected to each other. Not sure if that's all there is to it but maybe give that a try.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
Ranch Hand Pickup Truck Grill Guard (A49461)
Ranch Hand Pickup...
CAT 420F2 IT (A50854)
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
