Back up switch for JD LT150
   / Back up switch for JD LT150 #1
DonBow11
Olympia Washington
1956 JOHN deere C40
I have a JD LT150 automatic riding mower and I bypassed the back up switch that turns the blades off when you go into reverse by compressing the switch and tapping it closed. Does anyone have the correct wiring diagram to bypass the switch altogether? Thanks
   / Back up switch for JD LT150 #2
Is it normally open, or is it normally closed (normally being when moving forward) ? They go to some lengths to keep someone from bypassing the RIO system.
Apparently taping it doesn't work well?
   / Back up switch for JD LT150 #3
I had a LT155 and I took the switch off the frame and chicken banded it to the frame so when you hit reverse it does not trigger the swtich to shut off the blades.
   / Back up switch for JD LT150 #4
Timmy that's my problem, when I hit the reverse pedal, it shuts down the mower. That might be the fix I need. Thanks!
   / Back up switch for JD LT150 #5
Why are you willing to by-pass a reliable safety feature on your Ride-on?
The RIO switch is a simple switch placed conveniently on the dashboard which acts as an aide-memoire to ensure you consciously 'choose' to mow in reverse.
:wrench:
   / Back up switch for JD LT150 #6
Spanner are you talking about the yellow push button under the steering column on the left side of the dash board?
   / Back up switch for JD LT150 #9
I'm just a little confused by your posts. Correct me if I am misunderstanding:
When you press the reverse pedal with the blades engaged and mowing your engine cuts out? This is supposed to happen.
To prevent the engine cutting out when you want to mow in reverse this 'yellow push button' needs to be pressed before you touch the reverse pedal. Once you begin to move backwards, with the blades still mowing, you can release the yellow button.
But:
I replaced it last year and it still wants to cut off.
You replaced the yellow button ? and why ??
:wrench:
   / Back up switch for JD LT150 #10
But:
:wrench:
i replaced the button because after i depressed the the button in and then depressed the revers pedal, it still wants to stop running.
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2021 Exmark 60in Zero Turn Mower (A49461)
2021 Exmark 60in...
2015 Rogator RG1300B Spreader/Sprayer (A50657)
2015 Rogator...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
