Back-up Generators
/ Back-up Generators #1
AHNC
Nevada City CA
Kubota BX 2660 & BX-23
I'm looking for a back-up generator for my house. I'm thinking, from the Generac website that a 17 kw unit would do. For those that have done this, any comments, experience or suggestions would be much appreciated. I'll be running propane. Last winter, was pretty intense from a power loss standpoint here. Approx 15-18 days.
/ Back-up Generators #2
17kw should be plenty for most homes... since you have propane... do you heat and cook with propane?
The best way I know is to figure your loads and go from there.
You might have someone calculate how much it is going to cost per hour to run with the anticipated load...
I've run a whole house during the Loma Prieta Quake on a Honda 5000... power was out for days... gas was OK... so heat and hot water not a problem and the generator was able to handle the oven OR a couple cooktop coils no problem...
The nice think about propane is it shouldn't get stale... the trade-off is not much you can do to refill if the outage goes for days...
My first home, 1200 square feet 3 bedroom, only had a 3.6kw electric service from the Utility... 30amp 120 volt...
/ Back-up Generators #3
If the outage goes for days a normal 500 gal tank will have that covered. IF it drags on to weeks is when you may have issues. But supply of propane is likely going to be much more abundant than diesel at that point. You can always acquire 20lb tanks for short emergency rationing periods. (again easier to find than diesel when your 2+ weeks into an outage)
most houses can be run on comfortably 10Kw. If you have livestock needs then certainly more KW is better than less.
/ Back-up Generators #4
Generac say a little more the 2.5 gallons of propane per hour at full load... I was looking for a number at half load and couldn't find it...
/ Back-up Generators #5
My current house has a 12kW diesel generator in a shed about 25 yds from the house. It was installed some years before I bought the place. It has a 250 gallon heating oil tank holding winter diesel - I live in central BC and it gets down to -40 F/C once in a while.
The diesel is sized to match the house service of 100 amps. That is enough to run the heating system (main is a heat pump, back up is propane furnace), the cook stove - in fact all the normal appliances. The diesel burns 1 gallon every two hours at 50% load or there abouts IIRC.
I have had no trouble starting the genset in the cold weather - there is a glow plug system which makes things easier.
As far as propane vs diesel - the propane was more expensive and less efficiant (i.e. uses more fuel than diesel). Propane is easier to fuel with 100 lb gas bottles readily available and filled. With my propane back up furnace uses one 100lb bottle in about five days with temps around 0F or -15C. I don't know how a propane generator would run in those temperature.
Footnote. Years ago I had a F150 with dual fuel - gas and propane. When starting on propane in cold weather, the different metals in the valves and components allowed propane to escape/leak. Once warm the propane leaks stoppped. Needless to say I used to start the truck on gas and once it warmed up, I would change over to propane with no further problems. I don't know if this could be an issue where very cold temperatures are concerned - possibly modern products perform better ?????????
Jim
/ Back-up Generators #6
Make sure you get the carb heater. It's an option that Generac doesn't push. All the Kohler gensets I install here in the North come with it and the service guys say you will need it when the temps drop to sub-zero. Don't let you're propane guy undersize you're tank.
/ Back-up Generators #7
Not sure, but would probably need 40# or larger cylinders, I would get 100#ers. The liquid needs headspace to vaporize and at 2.5 gallons per hour the 20 lb. would ice over and vapor lock most likely sometime during the first hour of use. And depending on where you get propane, a 20 lb. tank only holds up to 4.5 gallons of liquid.
/ Back-up Generators #8
Here is an excellent article on sizing propane tanks for gensets.
Care and feeding of Propane Fueled Generators « Engineering Radio
The necessary tank size may be much larger than you first think.
/ Back-up Generators #9
AHNC,
I pondered the same thing several years ago and decided on the gas version of Generac's 17,500 watt portable. I have propane on the property to heat the pool (my money pit) but I didn't have near enough to run maybe 2 days at the most on propane. I looked at a gen set for the tractor 10KV unit and didn't like that. I chose gas as the best for my needs since I have 3 cars and I can siphon fuel from them if I needed to. The problem I have now is since I got this thing we haven't had a power outage for greater then 4 or 5 hours at any given time so I'm second guessing my self on selling this unit. I can tell you this thing is a beast, easy to work on and runs well even on stale gas. I do start it monthly to charge the battery but I bet you she doesn't have 10 hours total run time in 3 years. Now that I said this my power going out soon.
Malvern
Thanks for the replies and advise. I currently have a stone fireplace with an old Earth Stove insert in the place. It is incredible how much fuel an insert can consume and generate so little heat. So after 25 yrs with no wood stove I went shopping for a new stove. The old one is coming out and the stone fireplace is coming down regardless. The Vermont Castings Encore I want is in the neighborhood of $2,600. The Jotul 400 option is a bit less. Plus new metal chimney, stove pipes, accessories I've got to be approaching $4k. With that kind of money a generator is absolutely the better choice, although I'd like the stove too.
Sizing on my part is way over I'm sure as I just filled in the blanks on Generacs site and my equipment is more efficient than most. I have replaced the central furnace/AC with high efficiency Mini-split heat pumps. As well, I have two Rinnai Energysaver DV gas wall furnaces. They only draw 33-55 watts. A Rinnai tankless at 50W when running. I'm not sure of the well pump sizing but it is a dug well with water about 50-60 down, so no huge draw there. So my first glance sizing will tumble back to probably...10kw?, when I actually do the fine figuring. Maybe less!
Also, being in the gas business I have always maintained that the way to do propane is to buy a 1000 gal tank and bury it. That way you can carry through the mid season demands without having to re-fill, unless you have a big load. I'm working on a new water line, underground power service (trees fall/snow/ice took mine off the side of the house twice last winter) and a new gas tank/line location in the same trench before winter hits. Btw, low temps here in the foothills are about 20f.
/ Back-up Generators #11
You could put an ammeter on your electrical service and read your demand at any time. As in the draw of the well if you are concerned.Your electrial meter outside might ell you and your elec. bill has more data as to loads. Just a thought? What is it about burying your propane tank?Doesn't it need to be coated?
I notice that I haven't updated my profile. I just moved from MA to Nevada City CA. Only about 1.5 ac. Shading the house I have about a 3.5' Doug fir, 4.5' Sequoia, 2 English Walnut, a 5' Black Walnut. The spread on the Black, with the extreme (for here) ice/snow last winter brought down a lot of the blacks branches, which took the power lines. It's an old place. In the attic I've found newspapers from the 1880's. It's a project. I need another one, right:thumbsup:
I got rid of a lot of my gear/stuff/treasures prior to the move, but I looks like I'll still have the mother of all garage sales here soon. Moving after a lifetime of accumulation is a trip in itself!
/ Back-up Generators #13
It sounds like you have a beautiful site? The underground service should not be too tough, other than roots.
/ Back-up Generators #14
Smart Meters are supposed to be able to chart actual time of use demand by logging on to the Utility's site.
Might help you in sizing.
My former neighbor moved to Grass Valley CA and they were always have storm power outages... he hooked up his Miller Welder to run the house after the first time they were out 24 hours and his wife wanted to move back to Oakland...
/ Back-up Generators #15
A couple years ago we installed a Generac 20kw that runs on propane. It's one of our favorite features of the house now. I actually look forward to power outages. (well, sort of)
We installed a separate 250 gallon tank that feeds the generator and I had them run a second line to my shop where I hope to one day install a heater.
I chose the 20kw because of the price (got it online from some place in AZ) and it came with the aluminum enclosure and a 200A service entrance rated switch. This allowed me to install it outside on the power pole where our PG&E service comes in. That way the entire property is powered instead of just the house or just a few circuits.
20kw is probably more than we really need, but it allows us to run just about anything without having to think about the load we are adding. Our electric clothes dryer is the largest appliance.
I too looked for a gal/hr usage for 50% load and did not find one. But I figure we can go for a couple weeks on a full tank (80% full) as long as we shut it off overnight and only run it about 8 hours a day. We have a wood stove for primary heat, so we don't need it going all the time.
The auto start and switch over is great. I also have battery backups for the computer and satellite TV. First time the power went out I was on the computer. The lights went dark, but computer stayed on because of the UPS. Then about 10 second later the generator cranked up and we had full power again. The UPS only has to carry the load for less than 30 seconds. I added the UPS to the satellite TV because it takes 5-10 minutes for it to obtain a signal after the power comes back on.
-Jeff
/ Back-up Generators #16
It's important not to overlook a UPS circuit for critical devices.
Here, at the hospital, the Generator must start, come up to speed and transfer the load withing 10 seconds...
I have two special circuits with battery back-up to cover the 10 second down time...
/ Back-up Generators #17
The fuel consumption rate for LP gas is 1.89 gallons per hour at 1/2 load and 2.90 gallons per hour at full load for the 20k unit..
/ Back-up Generators #18
I can't imagine the water heater at 50W? Maybe 5000W?
I have a three bedroom, 2.5 bath 2300sq/ft colonial. I have oil furnace heat and hot water and a well. I have electric stove and washer and dryer.
I power my house on a 5500 watt gas generator, i mounted it on wheels and store it in my garage. I roll into driveway and plug in when needed.
I easily power my house for 12-14 hours per 6.5 gallon tank.
I run my heat, hotwater, well, TV's, appliances etc, with no problems at all.
If running the oven or stove tops I'd not be able to run anything else at the same time. I've not tried the electric dryer, no need during an outage.
I've been out for up to 5 days straight with no issues. I fill at night and then fill in the morning.
I paid $399 for the generator during a day after thanksgiving day sale.
What I like about my set up is, my generator is totally portable so I can use for many purposes, it was cheap but very reliable, I've had for a few years now.
What I don't like is that it runs on gas. Gas is just plain junk today and I'm sure to treat every tankful.
Search on the site, there are many posts on this subject.
This reminds me to run the gas through my machine as it's been sitting for some time.
Joel
/ Back-up Generators #19
I have the 15kw Generac running on LP, the old version of the 17kw unit they sell now. I installed it 5 years ago and added a hour meter since it did not have one-it now has about 120 hours on it and never has given me one problem yet.
My only issue is the steel enclosure is rusting badly, now they offer a aluminum one for a small upgrade price-GET IT!:thumbsup:
I bought mine from Norwall Power Systems, great prices and great service.
/ Back-up Generators #20
Remember to install a generator transfer switch. Also, Siemens now offers a 200 amp panel with intergal manual/automatic transfer switch that can be installed in place of your existing panel. Ive used them and their a great device. can operate up to a 125 amp generator with them.
2013 Wacker Neuson LTN6 (A64911)
2013 Wacker Neuson...
2016 BIGHORN 5th WHEEL (A67714)
2016 BIGHORN 5th...
1996 John Deere 7700 (A64911)
1996 John Deere...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2009 INTERNATIONAL 7600 6X4 T/A  VACUUM TRUCK (A66091)
2009 INTERNATIONAL...
PALLET OF WOODEN STAKES (A68842)
PALLET OF WOODEN...
