Thumb Back hoe thumb picture
/ Back hoe thumb picture
Mark,
Thanks. I'll let you know how it comes out. If I get it this week it will get put on this weekend along with the 50hr service.
Rowski
Mark,
Well put the thumb on today. And used it tonight. Set about 25 stones (med to large) in a small water hole (aprox. 10' x 18') from the over flow of our resevoir. Had to load the stones first in the dump truck. Beats chasing them around trying to curl them in without a bucket full of dirt /w3tcompact/icons/crazy.gif. Dump them into the hole and set in place.
The thumb works really, really well. Now if I could just twist the dipper stick (any ideas) /w3tcompact/icons/wink.gif. I was trying to set the rocks with out the thumb and it was almost impossible. My dipper stick is two halves welded together. I had to grind a channel in the backside of the mounting plate so it would mount flush before welding. This was a pain and time consuming but I wanted it done right. By the way, blew a hydrualic hose on the hoe last night. The idiots that put the hoe together (at the factory didn't route a hose properly. When the boom was put into the park (all the way back) the block for the hyrdrualic hose on the boom pinched the dipper stick hose. I was lucky I was working of center, it blew the fluid over my shoulder. Got a new hose made, installed it and routed properly. Still waiting for a new spool valve for the boom problem, hopefully this coming week.
Anyways, Many thanks. If the hoe is of a large size (9.5 ft) I can say the thumb is well worth the money.
Rowski
/ Back hoe thumb picture #13
Rowski - Thanks for the note; I'm glad you like it.
Your ruptured hose emphasizes why we should never work under a raised backhoe or loader bucket. Sometimes we forget how little is holding them up.
Mark
Tank Only (A59076)
Tank Only (A59076)
204549 (A52707)
204549 (A52707)
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2020 DRAGON ESP...
