Back Hoe for MF202
   / Back Hoe for MF202 #1
richn
I have an MF202 industrial with a front loader and would like to get a BH attachement. I am a bit new to this and I am not sure exactly what I should be looking for. I would like a BH attachement that connects to the 3 pt hitch, the loader has a pump that could also be used for the BH. I know the 202 came with a custom BH but I would like to get one that attached to a standard hitch that I could still use if I replace the tractor. Any thoughts would be helpful
   / Back Hoe for MF202 #2
If you was to run across one of the original hoes, it would be a much, much stronger hoe. There is no comparison between the factory hoe and a three point hoe.
   / Back Hoe for MF202 #3
RichN
The old Davis 185, 210 & 220 backhoes would most likely be a direct bolt on. There may be newer backhoes that will work but those three were common for the era. I beieve the 220 was able to shift side to side on rails. The 185 and 210 could be bolted to the middle or either side of the frame.
I have a Ferguson 35 with a 210 backhoe. The MF 202 would be much better suited for the BH than my 35.
BTW wherabouts do you live?
Erich
AGT Skidlaoder Post Hole Digger (A50774)
AGT Skidlaoder...
John Deere 47" Snowblower (A50774)
John Deere 47"...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Case International B600 Silage Blower (A50774)
Case International...
