Backhoe Back hoe cylinder woes
   / Back hoe cylinder woes #1
chopitrakeit
Hi.
Just found my 4530 hoe bucket cylinder had the nut back off. It stopped working. I switched the hoses to the small arm and it still was not working. Tool cylinder apart and nut had come off piston???? It is a locking nut and it was off the rod end. Easy, yet messy, fix. No parts required. Hard to believe it just turned off.Anyone had this happen?
Mike
   / Back hoe cylinder woes #2
did the piston come off the rod inside the barrel? i can't imagine how you would get it out if it did. i just put mine back together and wondered how tight that nut should be, i don't have a torque wrench but used a 24" cresent to tighten it down and don't think it's going to go anywhere.
Heavy Haul trailer (A49461)
Heavy Haul trailer...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
