Back hoe bucket has two pin holes??
   / Back hoe bucket has two pin holes?? #1
futuresweets10
I noticed that when I got down bellow about 3ft the bucket didnt tilt out enough to be able to dig deep. I moved the pin from one slot to the other to allow the bucket to swing out further, but obviously it wont fold in flat against the arm now (which isnt a problem). What is the other setting for, as it seems to be worthless for digging.
   / Back hoe bucket has two pin holes?? #2
I find the "inner" setting handy for grasping things with the bucket...
My bucket will nearly touch the dipper and I can grab branches and most anything else between the dipper and bucket... Also handy if your hole is deep enough to dig under a pipe or other utility.
   / Back hoe bucket has two pin holes?? #3
JD calls one the power digging position and the one that folds nearly to the arm is a setting for loading dump trucks with the back hoe.
The Power setting is better for digging up stumps i have found.
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2018 MACK CHU613 PINNACLE DAY CAB (A53843)
2018 MACK CHU613...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
Cattle Gates / Feeder (A53117)
Cattle Gates /...
International Acid Tanker Truck (A52377)
International Acid...
