Back dragging with bucket
   / Back dragging with bucket #1
zpilot
Conn.
CK2610
I have a CK2610, when I try to back drag top soil with the bucket the bucket no matter the angle will fold back quite a bit making spreading top soil not very easy. Any suggestions? TIA.
   / Back dragging with bucket #2
Loader in float mode?
No it is not.
   / Back dragging with bucket #4
Are you talking about the bucket curl function?
Yes.
   / Back dragging with bucket #6
"Floppy Bucket Syndrome". Caused by the volumetric difference between the rod side and piston side of the cylinder. The Low Volume side (Rod End) empties fluid faster that the high volume side causing cavitation of the hydraulic fluid.
Simple fix, install a Flow Restrictor in the Low Volume side at the Loader Quick Coupler (White Hose). This will slow the bucket movement down, but will also act to keep both sides of the cylinder balanced and eliminate most of the "Sloppy Bucket" effect.
Hope this helps
   / Back dragging with bucket #7
Once you set the bucket on the ground at the angle you want, hold over on the loader joystick a bit longer till you get tension on the bucket (see/feel the bucket start to angle slightly more) Then backdrag.
Thanks will try it tomorrow.
   / Back dragging with bucket #9
Yes, this is what I have to do with my CX as well, also I notice if I run too low of RPM it will do it more often. Also, the flow restrictor is a great idea.
   / Back dragging with bucket #10
Tractor buckets are not exactly the best tool for this task.. rear blade, box blade or land plane would be a better choice.
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
1997 GROVE TMS750B 50 TON CRANE (A51222)
1997 GROVE TMS750B...
71057 (A49346)
71057 (A49346)
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
