</font><font color="blue" class="small">( A 3PH is designed to pull things. The top link in that mode of operation is pushing against the tractor and the pulling is done by the lower arms. When you start pushing with the rear blade the forces are reversed, the lower arms are pushing and the top link is pulling on it's mount.
What many including myself have done is install the heavy duty top link bracket that is used when a back hoe attachment is used on your tractor. That bracket will help protect the top link mount when using the blade to push with.
Use your head and go a little slower and there should not be a problem.
Randy )</font>
Intresting concept, but not exactly fact.
A top link mount is designed to be "pulled on" when lifting anything with the 3-point hitch. It would/could be in compression when using most equipment, but when LIFTING that equipment, forces are reversed.
On some smaller tractors, the components are built with marginal strenght (to save weight?) .
