Rear Blade back blade or landscaping blade
   / back blade or landscaping blade #1
pekan
Baker-Brook N.B. Canada
Kioti CK 35 2009 with front loader
:confused2:Hi everybody i need some commend between a rear blade and a landscaping blade to maintain forest trail on wood lot which is the best for that. and that for a Kioti CK35 :confused:
   / back blade or landscaping blade #2
By rear blade, do you mean a box blade?
How important is $$$?
Yes a landscaping rake and a rear blade not a box blade
   / back blade or landscaping blade #5
Your question should be, what should I buy first? :laughing:
Without actually seeing it, I would say rake, blade then box blade. With the premise of starting off with moving the least to the most amount of material. In reality you may need the box blade first, depends on what "maintain" might entail.
   / back blade or landscaping blade #6
I have about a mile of woodlot and field trails and don't use any of those to maintain them. I have a scraper blade but it never goes on the trails. I just use my mid mount mower to mow them (keep it up high) and a chainsaw and various branch cutting implements to keep the brush under control and out of the way. Trails are beautiful.
   / back blade or landscaping blade #7
I agree.
   / back blade or landscaping blade #8
We need pictures. I dependant if your road/trails are flat, side slopes and elevation changes. Is water an issue for erosion, heavy vehicle traffic.
I don't have a landscape rake but I can see it uses. Rear blade have the advantage, than again so can do box blades. I would think the rake can probably do the same job as a rear blade and more. For what it's worth I rarely use my rear blade.
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
CATERPILLAR H90C HYD HAMMER (A52707)
CATERPILLAR H90C...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
