Back blade on front 3-point hitch -- Good idea or stupid?
   / Back blade on front 3-point hitch -- Good idea or stupid? #11
Installing a 2" receiver on the front and using a Snowsport plow is quick, safe, and lower cost than installing a front 3-pt. You can even use the plow on anything else with a receiver, like your truck. There are plenty of videos showing how these plows work too.
   / Back blade on front 3-point hitch -- Good idea or stupid? #12
For mine, I just welded a couple of pieces of 11" channel to the sides of a cheap HF quick hitch, then welded the JD hooks and pins to the channel.
Nice! And a big DUH from me - I've had a HF QH in the one shed for over 10 years and never used it. I'd need to do something a bit different at the bottom for standard QA pins since mine isn't a Juan Deere. Wish I'd have seen this before starting on mine.
   / Back blade on front 3-point hitch -- Good idea or stupid? #13
I think I would still want the springs in the blade, just in case you hit something.
The beauty of a front 3 pt + PTO is that you can just use regular 3 pt implements, instead of getting stuck with very expensive proprietary front hitch system and attachments that some big brands offer.
   / Back blade on front 3-point hitch -- Good idea or stupid? #14
The one thing I did wrong with mine as shown on post #2 of this thread is that I just welded the quick hitch to the SSQA plate I should have spaced the bottom of the quick hitch out 4-6 inchs with the top being flat to the SSQA plate as I don't have as much curl back as I like some times when moving things around.
I do wish the actual add on front 3 points weren't so outrageously expensive.
Utility Tilt Trailer (A55787)
Utility Tilt...
2018 Caterpillar 287D Compact Track Loader Skid Steer (A56857)
2018 Caterpillar...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
Toyota Forklift (A55973)
Toyota Forklift...
