Back blade on front 3-point hitch -- Good idea or stupid?
   / Back blade on front 3-point hitch -- Good idea or stupid? #1
EdwardL
Emax 20
Has anyone ever tried putting a 3-point hitch on the front of a compact tractor and using it to mount a back blade to plow snow? -- I know there won't be any springs to dampen the blade hitting something, but my drive way is short and there are no curbs to hit.
Just wondering if this is a stupid or practical.
   / Back blade on front 3-point hitch -- Good idea or stupid? #2
I have a quick hitch mounted to an SSQH plate. I use it for moving and setting things in place it also has a trailer hitch receiver in it.
That said I seldom use it, the most often use is to put 3 pt implements into my little shop that only has a 7 ft high door, when I'm going to work on them.
I was going to use it with my york rake for cleaning debri off my yard, didn't work worth a damn.
It would put your back blade way out in front of your tractor and make it difficult to control.
   / Back blade on front 3-point hitch -- Good idea or stupid? #3
A VERY COMMON set up in Europe. They don't really go for FEL. Practical people! ;-)
Type "Hurlimann Prince" into google foo.
Select images from the menu bar.
Enjoy many images of front mount 3pt.
   / Back blade on front 3-point hitch -- Good idea or stupid? #4
I modified a western truck mount snow plow to mount on frame of my tractor. I use the hydraulic connections for loader to operate the plow. Pull two pins and disconnect four hoses and drop plow and can then attach loader. Even mounted that close it Still pushes front of tractor sideways in heavy snow. I have cross port relief valves on swing cylinders but no spring trip.
I have blower on the 3 point so this option works well for me.
   / Back blade on front 3-point hitch -- Good idea or stupid? #5
Inspiration
   / Back blade on front 3-point hitch -- Good idea or stupid? #6
Make sure you have sturdy cross bracing on the front mount linkage as you can bend the lower links going around corners. At a previous job the owner user a blade directly mounted onto the 3ph and bent the lower links(sideways) . There are no stabilisers on his front 3ph. Also he was blading dirt not snow.
   / Back blade on front 3-point hitch -- Good idea or stupid? #7
I wouldn't try it. A plow needs to be able to float (and NOT by using the FEL "float" position). It would be way too Rube Goldberg. If you want to have a front plow here are much better ways to do it.
   / Back blade on front 3-point hitch -- Good idea or stupid? #8
I made a front quick hitch for my JD 2520 and have used it for a rear blade, but not for plowing snow. My situation is that I have a poorly designed compost pile that is surrounded by railroad tie walls on three sides. I use my setup to reach over the pile and pull compost from the rear to the front when turning the pile.
That being said, I am aware that the loader is not really designed to be used in this manner and I am, therefore, extremely careful when doing it. I don't think it's going to hurt using it like this for moving loose material. I would be uncomfortable using it to do very much snow moving, maybe just for pulling it away from buildings/garage doors.
Attached pic is using the QH to move my box blade, but you get the idea.
Edit: It just hit me that you might not be intending to mount the quick hitch to the loader? If you are actually thinking of installing a three-point hitch to the front of the machine (ala European equipment) I will be interested to see it.
PS Edit: I also use my subsoiler on the front quick hitch for turning the compost pile.
   / Back blade on front 3-point hitch -- Good idea or stupid? #9
One of my back burner projects is a 3PH attachment for the QA on the loader. The primary use will be for a landscape rake to pull junk out of a fence row. With a bit of care it doesn't scare me to pull it. I wouldn't attempt to push it though.
   / Back blade on front 3-point hitch -- Good idea or stupid? #10
For mine, I just welded a couple of pieces of 11" channel to the sides of a cheap HF quick hitch, then welded the JD hooks and pins to the channel.
2011 Peterbilt 337 Hydro Excavator Truck, VIN # 2NP2HN7X6BM130882 (A54865)
2011 Peterbilt 337...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
Giy 59" Compact Wheel (A53316)
Giy 59" Compact...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump (A55787)
2025 60 Gallon...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
