Baby, It's Cold Outside, But Let's Talk A/C
   / Baby, It's Cold Outside, But Let's Talk A/C #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Is it too early to talk about AC units?
I'm in the market for something. The 6K window shaker I have is several years old and not terribly efficient any more. I can't do central or heat pumps or anything similar for a number of reasons. Mini splits might be an option, but even the less expensive ones are close to a grand, plus installation. I know many of them are self install, but I don't have the gauges or evac tools required and I have concrete block walls to deal with.
Most of the window shakers I see don't have a fan that pulls in outside air for those cool nights. They usually only have a recirculation fan which doesn't help much. The one I have is narrow enough that I was able to rig up a way to let outside air in beside it when I want to.
So, bopping around the web this morning, I see this thing:
iu
Midea MAW08V1QWT
8K BTU with a 15 SEER that looks like a self contained mini-split type gizmo. Let's you open and close the window as needed.
Probably not what I'll go with, but interesting.
Still looking. I need a remote too with auto-temp and timer settings which my 6K has.
   / Baby, It's Cold Outside, But Let's Talk A/C #2
I just installed a Daikin 15K ductless heat pump in my garage / workshop. It has a full featured remote control and timer. I hung the outside unit on brackets mounted to the block wall. I punched a 3" hole through the block with a hammer & chisel and mounted the indoor unit on the other side of the same wall. The unit comes pre-charged with gas and I rented a gauge set & vacuum pump from a local tool rental business.
The unit does not bring in outside air, it just recirculates. If I want fresh air, I open a window.
The project cost $2800 and took me 1 1/2 days to do. Smaller 7K units are available and are much cheaper. If you're handy with tools, it isn't that hard a job. The toughest part for me was getting the 100# outdoor unit up onto the wall brackets. I used the bucket of my tractor to do the lifting. This can be avoided if you put the unit on a slab at ground level but I didn't want to block the walkway.
   / Baby, It's Cold Outside, But Let's Talk A/C #3
there are some mini split systems that don't require lines to be vacuumed.
Mr cool has such a unit. DIY.
Other than that, you're pretty much limited to a window shaker, which would be your cheapest option
   / Baby, It's Cold Outside, But Let's Talk A/C #4
You can get an inverter AC window unit. Either U shaped or regular. Basically a cooling only mini split in a single unit.
   / Baby, It's Cold Outside, But Let's Talk A/C #5
yes, he can. The one he has pictured is, or can be inverter .
Due to efficiency codes, Won't be long, everything will be inverter
   / Baby, It's Cold Outside, But Let's Talk A/C #6
I recently self installed a Mr Cool DIY unit. Hardest part of the install was running some romex through the crawl space for a new circuit.
An issue I had the the precharged lineset is that you apparently have to tighten it down, loosen it a turn and then retighten it in order for the valves to open up. Took a phone call to tech support to figure that out since it didn’t say that in the manual.
I’m also getting ready to get one of the LG inverter window units. A little pricey but should be worth the upgrade over a standard window unit.
   / Baby, It's Cold Outside, But Let's Talk A/C #7
The lines are still vacuumed, they are just pre-charged by MrCool. If one ever needed service, they would have to vacuum them again.
   / Baby, It's Cold Outside, But Let's Talk A/C #8
correct. Point is, you don't have to vacuum to install
   / Baby, It's Cold Outside, But Let's Talk A/C #9
The biggest equation I think you're missing isn't the actual efficiency rating, but that the the system will be rated at a .5 static vs a .1 static.
   / Baby, It's Cold Outside, But Let's Talk A/C #10
Can you elaborate on this a bit more? Thanks!
All the best,
Peter
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
378813 (A51573)
378813 (A51573)
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
RIGID POWER DRIVE/HAND HELD THREADER (A53843)
RIGID POWER...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
84'' skid steer bucket (A53421)
84'' skid steer...
