Loader B9200 FEL will not lift...
   / B9200 FEL will not lift... #1
dave c
kubota b9200
Hi ...well I have a B9200 that just started making a noise from around the area your feet rest while sitting in the seat.....and the front end loader will not raise.....it did a little but was jerky....I checked fluid and it is full.....did i loose a pump?? or do i need to clean the filters....I guess it has filters??:):) and guidance and help from u guys in the know will be appreciated...Thanks
   / B9200 FEL will not lift... #2
It may not be this bit not a bad place to start is to check that all your connections are ok and no quick disconnects(QD) have come undone, even partly. have a FEL issue few month back due to the PB QD was not staying connected. Just a thought.
   / B9200 FEL will not lift... #3
Any chance that the little valve/knob on the distribution block is not all the way in the loader position?
Thanks for the responses....I did turn the nut(17mm) on that valve but that didn't do anything...can it be stuck?? should i take it apart and see if something is stuck?? I guess I should buy a workshop manual :)
Carolina Dragonfly Pro (A57148)
Carolina Dragonfly...
2013 Chevrolet Equinox LTZ AWD SUV (A56859)
2013 Chevrolet...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
VERMEER RTX100 WALK BEHIND TRENCHER (A52709)
VERMEER RTX100...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
