B8200 HST transmission
   / B8200 HST transmission #1
PeteW
New Zealnd
Jinma 284. Shibaura SE4040
I recently bought a B8200 HST, a bit on the rough side. Transmission does not seem to take much load before it ceases motion. I drained the transmission oil and found some iron filings on the screen. I also got a 7mm ball bearing. Guess it doesn't look good. appreciate some insight !
   / B8200 HST transmission #2
A free parts manual from here might be handy... Kubotabooks.com
Blocked screens can certainly stop a tractor. But iron filings don't automatically mean major problems. And the ball bearing could just have been dropped by someone on the assembly line. I'd just clean the metal screen, replace the spin-on filter and the oil, and cross my fingers. I had a similary sluggish tranny. Cleaning the screens made a world of difference.
   / B8200 HST transmission #3
Are you in low range and it stops? Does the trans slip or stall the engine?
No, it does not stall the engine. It just stops moving like when confronted with a a bit more steep ground. i.e. it slips.This can happen in low range too.
Love you guys sense of humour. Or should I spell that another way!
About the clutch- might be slipping a bit. I've not had HST before, so don't know what the norm is. If I try and shift speed range with higher revs, it makes a noise i.e. cogs trying to mesh or something. Drop revs down to idle and it goes through clean and quick.
   / B8200 HST transmission #9
Will it pull a dead weight.:confused:
Any strange smells when it doesn't move?
   / B8200 HST transmission #10
I would want to know where the ball bearing came from! Would try to find an assembly diagram and parts list. Might be a real clue in that.
Then again, I don't even know what a B8200 looks like. :eek:
How's the weather in New Zealand? Every time I do a search on my geneology (Scottish lowlanders), it appears most of them went to Tasmania.
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2012 Ford F-250 4x4 Pickup Truck (A50323)
2012 Ford F-250...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
