B8200 4wd tractor - where is the hyrdolic fluid fill port
   / B8200 4wd tractor - where is the hyrdolic fluid fill port #1
dryland1
   / B8200 4wd tractor - where is the hyrdolic fluid fill port #2
Hyr_dolic ?
I doubt that there is one, I wouldn't want that stuff in my tractor.
IF there is one for hydraulic fluid that is likely to be somewhere around/on the rear axle.
From the back look around the top of the axle, maybe high and almost close to the seat.
Tractors are "like that", this is general guidance only.
There is also likely to be a "sight glass" for checking the fluid level, look for a glass/plastic clear "bubble" about the size of a thumbnail with one or two horizontal lines on it.
If two they represent high and low, if one it represents a recommended level.
Don't expect to find a dip stick, not saying they don't exist on tractor axles, but the sight glass is more common.
Again, general guidance; if using the tractor on steep slopes an extra gallon of fluid is often recommended.
   / B8200 4wd tractor - where is the hyrdolic fluid fill port #3
Dryland,
The filler plug is just left of the transmission shifter on top of the transmission housing.
The dipstick is just to the right of the shifter.
If you have a loader on the tractor, be sure to put the bucket flat on the ground for the correct position to check your fluid level.
Good luck - those old B8200s were excellent machines and still give good service given reasonable care!
HELI STRAIGHT MAST FORKLIFT (A51242)
HELI STRAIGHT MAST...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
GEHL RB1470 TOTAL DENSITY CONTROL HAY BALER (A51243)
GEHL RB1470 TOTAL...
Bobcat 753 Skidloader (AS IS) (A50774)
Bobcat 753...
2001 JOHN DEERE 8410T TRACTOR (A51243)
2001 JOHN DEERE...
1998 CATERPILLAR D250E OFF ROAD DUMP (A51242)
1998 CATERPILLAR...
