</font><font color="blue" class="small">( How is the rear outlet useful? )</font>
For under $100 you can purchase the aux hydraulic block that fits on the rear outlet which allows you to tap into the hydraulic system (you can't do anything with the rear outlet without the aux hydraulic block - the rear outlet is just covered by a plate.) You can then add one or more hydraulic valves to control remote hydraulic outlets. Useful for any hydraulically operated equipment like a hydraulic toplink or sidelink for your 3 point hitch, snowblower chute rotators, 3PH logsplitter, etc.
</font><font color="blue" class="small">( Any other advice related to these two machines would also be helpful. )</font>
Here are the
B2910 upgrade features:
Deluxe seat with adjustable parallel link suspension and arm rests.
Extendable lower link on the the 3PH arms. (Makes it easier to hook up equipment)
Ratching adjuster for the right side 3PH lower arm.
Cruise control lever to the right of the seat.
Telescopic/Tilt steering wheel.
As far as advice goes - buying a tractor is big investment, if you are planning to spend alot of time on or use it alot, keep the tractor a long time, etc. the additional features might be worth for you. They were for me. HTH.
