B7800
   / B7800 #1
Bill Hoffman
Coventry, CT
Kubota B7800
Hi,
Went to move a pallet of firewood with 3pt and the frame of a carry-all.
(used like a forklift) Wouldn't even make it budge. Used the front loader which did the job nicely.
According to the manuals, I believe The 3pt is supposed to have a greater lift capacity than the loader. Does anyone have any suggestions as to what may be wrong with the 3pt? It seems to work well with other loads, like a 5' bush hog.
Help?:confused:
Bill
   / B7800 #2
It might be that pallet is too heavy, especially if the 3ph can lift a 600 lb cutter.
Since you probably have no way to weigh the pallet of wood, you can try to lift it. If it won't lift, pull some of the wood off (say, 10%) and try again. Continue removing about 10% until the 3ph can lift the pallet. Then you'll have an idea what your 3PH can do. That wood may be wet and that may make it heavier then you estimate...especially if you could lift that pallet during the summer (when it's drier).
It is possible the relief valve is set wrong and is venting the hydraulic fluid at too low a pressure.
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
Headache Rack (A50860)
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
International 4700 Vibra Tiller (A51039)
International 4700...
2011 Ford Escape XLT SUV (A48082)
2011 Ford Escape...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A51039)
Ditch Witch 6510A...
