Bill Martin
In doing the 300 hour service I drained the fluid from all 4 drainplugs, removed the two filters, and cleaned the strainer. The manual states the system capacity is 3.83 gals. So I put in 3.5 gals to start and checked the dipstick, thinking I'd top it up afterwards. It reads well over the maximum level. Will the fluid level even out over time? Does it take some time for the fluid to work its way through the system? Should I drain some to get the level where it needs to be on the dipstick? Does it damage the machine to run it with the level higher than it should be? Thanks for comments and help. Bill
