B7800 transmission fluid capacity??
   / B7800 transmission fluid capacity?? #1
Fjord
Ontario,Canada
B7800
Hello
I just finished changing the transmission oil and filters on my B7800. The manual states that the transmission capacity is 14.5 litres. I drained it from the 4 locations noted in the manual and emptied the filters into my drain bucket and only got 12 litres. When I filled it back up with UDT it also took only 12 litres to fill it to the full mark on the dipstick after running to be sure the filters were also full. I was just wondering if anyone else had experienced the same thing.
   / B7800 transmission fluid capacity?? #2
Hi!
I've had the same experience with my B7800, but I don't remember the actual difference between the stated capacity and the actual capacity (fluids I drained and refilled). best wishes,
Barney
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
TRAILER AXLE (A51244)
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
